ADVISE? blower or spray?
looking for 50 to 75 more horsepower. should i go with the wipple,kennebell or just a 75 shot? My truck runs constant12.0 to12.3 on the stock block and supercharger.I have all the bolt ons
2.80 upper 6lbs lower
2400 stall converter
c & l upper
jdm power tube and intake
ele fan
dyna tech long tube jdm x pipe silver bullet
line lock traction bars, qa1 adj shocks rear
acc th body
trans pan and oil
boost by pass
plugs injectors all done by jdm & tuned race street hot cold
on the dyno it put down 480 rwhp race tune
am i pushing the block or can i get more and how to get more power? thanks
c & l upper
ele fan
acc th body
trans pan and oil
boost by pass
Your pretty much on the edge of blowing your engine. If you want the engine to last, rebuild the block then strap on either a whipple or KB.
Ive seen way too many people nade thier engine because of too much boost on a stock block.
Ive never really been a fan of spraying either wet or dry.
I would rebuild the block (Rods, Rings, Valves, Springs etc)
Strap on either a Whipple or KB
just my 2 cents.
just my 2 cents.
from everything i have read, our blocks can only hold around 500 rwhp with a blower and around 600 with the right turbo set up.
Id agree with the above post, rebuild your motor if you want to add that much power, and I would def go with a blower over N2O any day.
You can find a used KB for around $2000 just look around.
good luck
good luck
thanks for advise
just my 2 cents.
just my 2 cents.
thanks for everones advise
