Newbie Help
Old Jul 21, 2006 | 12:27 PM
04SonicBlueL's Avatar
Newbie Help
What can I expect to gain if I add a 2.76 upper to the these already installed mods JLP CAI, #4Lower, Diablosport Predator, NGK-6 Plugs, FTVB, ported SC, TB, PL.
Old Jul 21, 2006 | 02:59 PM
Eds 01 Lightnin's Avatar
Most will tell you "BELT SLIP"!
Old Jul 21, 2006 | 04:23 PM
LatemodelRacer2's Avatar
IT wil be a good combo to add since you have a port you lost low end which will be regained. Is that a off the shelf predator? I hope not because that will be like making a apointment for a blown motor
Old Jul 21, 2006 | 04:52 PM
buzzyinmich's Avatar
I wouldnt put on a 2.76 upper. You will be losing top end speed. And a guarantee your belt will scream worse then a virgin getting gangbanged.
Old Jul 21, 2006 | 05:05 PM
How do you figure that you will loose TES w/a 2.75 upper? Maybe if you're running 140mph!
As for belt slip...I have been running a 2.75 upper for 4 years now along with a Metco Idler set up and have never experienced belt slip!
Old Jul 21, 2006 | 05:33 PM
evo's Avatar
evo
Just go with a 6# lower.
Old Jul 21, 2006 | 05:36 PM
evo's Avatar
evo
I didin't lose any lowend TQ with my port w/ a 4#.
Old Jul 21, 2006 | 06:17 PM
I chose not to go with the 6lb lower due to reading about people calling it the grenade. was just wondering if I would see any gain with the 2.76. Thanks for the info. Kat
Old Jul 21, 2006 | 06:40 PM
You should see about 1 to 1.5 #! As previously indicated you will need to get an idler kit or you will probably see some belt slip which will negate the add'l boost.
Check the used parts forums as I have seen them advertised used.
http://www.nloc.net/vbforum/forumdis...485&order=desc
One other thing...you may have to grind down the fins on your snout (as I did w/2.75) for clearance! No problem though!
Old Jul 21, 2006 | 08:09 PM
You are a very rare case. back when i had my steig on a stock block. my truck lost 18rwtq untill 4500 but gained after that but what good is that. I added the upper and it was a all around improvement
Old Jul 21, 2006 | 08:15 PM
evo's Avatar
evo
Mine wasn't a Steig port. Bill (wjm) ported it. I was looking at my dyno sheets and aside from no loss it ramped up a lot faster. I wonder if it is because i only have a catback stock cats?
Old Jul 21, 2006 | 09:02 PM
Eds 01 Lightnin I noticed you refered to it as a 2.75 what is the actual size. Thanks
Old Jul 22, 2006 | 09:21 AM
Mine measures 2 and 3/4". I haven't heard of a 2.76, but, that doesn't mean they don't exist!
