How far to drop...
Old Jul 11, 2006 | 07:52 PM
01 Bolt's Avatar
How far to drop...
.... how much drop do you all have on your Lightning?
I am thinking about 3.5 - 4. But I would like to see some pics first. I think 1-1.5 would be a waste. What all else does one need to do after a drop?
Old Jul 11, 2006 | 08:45 PM
Falcon11's Avatar
4" in rear should make you perfectly level with the front (if the front is stock). With that being said, just go with JLP's shackel. You have the choice of a 2, 3, or 4" drop. 4" drop is really like 2 3/4"-3". I'm 1/2" higher from rim to wheel well in the rear than in the front (almost level). But I have an '04 which are higher in the rear from the factory than your '01.
If your looking to lower the front as well, you have many options. IMO the best looking drop is what the Hotchkins kit gives you.
Old Jul 11, 2006 | 09:18 PM
StruckBy99's Avatar
Front: Belltech 4804 coil with 3/4 turn cut off. Belltech shocks with short Energy Suspension bump stops. 3" lower than stock.
Rear: Belltech shackle on lowest setting and Western Chassis front spring hanger on lowest setting. Belltech shocks and Western Chassis c-notch kit with urethane bumpstops. 4 3/4" lower than stock.
The rear of my truck is still 2" higher than the front because I'm running a 2" taller rim/tire back there.
Jason
Old Jul 11, 2006 | 09:29 PM
bnehila's Avatar
Jason
ANY PICS OF THE C NOTCH?
Old Jul 11, 2006 | 10:30 PM
StruckBy99's Avatar
Not yet, but I'll try and take one.
Old Jul 11, 2006 | 11:29 PM
HalfTime's Avatar
2 1/4" drop in front. 1 3/8" drop rear.
stock...
Old Jul 12, 2006 | 03:10 AM
mecca's Avatar
Western Chassis 4/6
Here is my Western Chassis 4/6. It consists of Lower Control Arms, Coil Springs, Flip Kit, Shackles, and C-Notch.
-Mike
Old Jul 12, 2006 | 01:56 PM
Black02SVTL's Avatar
Do you need a c-notch to run a 5 or 6 in. drop in the back? Or can you get away with front hangers, shackles, and shock extenders with smaller bump stops?
Old Jul 12, 2006 | 02:01 PM
thepawn's Avatar
2.5", rear to match, courtesy of ROUSH.
Old Jul 12, 2006 | 07:15 PM
MAT2CH's Avatar
Mine is a 3/5 drop, and it came with the truck.
Old Jul 13, 2006 | 12:00 PM
LatemodelRacer2's Avatar
ah mecca using the flip kit.......i wonder what just the flip would drop it without using the drop shackle too? Ive been wantin to go this route some time but havent seen anyone do it
Old Jul 13, 2006 | 07:15 PM
Falcon11's Avatar
Is that the standard drop on the Hotchkins kit?
Old Jul 13, 2006 | 09:37 PM
JeffsLightning's Avatar
FRPP front springs and rear shackles at the lowest setting with Hotchkis leafs. SOCAL shock extenders...
Old Jul 13, 2006 | 09:49 PM
68Ranger's Avatar
FRPP (Ground Force) kit. Ride still feels the same, and it hasn't scrubbed yet.
Old Jul 14, 2006 | 09:01 AM
Red_02_L's Avatar
Where do you buy the SOCAL shock extenders?
