Ball Joints gone!!!
Old Jul 5, 2006 | 09:58 PM
bnehila's Avatar
Ball Joints gone!!!
I got an 04 Lightning, 25000 miles, and ive owned since new. I lowered at about 8000 miles with Eibach Pro Kit (RPM Outlet). Ive been hunting down a bad vibration and found both lower ball joints have about 3/16 play. Anyone have or know of a better than stock ball joint or should I just replace with stockers.
Old Jul 5, 2006 | 10:28 PM
svtdvm's Avatar
http://store.summitracing.com/egnsea...115+4294907388
Old Jul 5, 2006 | 10:59 PM
Tim Skelton's Avatar
What he said. The stockers are junk compared to Moogs.
Old Jul 5, 2006 | 11:28 PM
bnehila's Avatar
thanks, im gonna go ahead and replace with the moogs. Skelton, do you have any specific alignment spec that you run?
Old Jul 5, 2006 | 11:43 PM
TXSVTLIGHTNING's Avatar
funny thing about Moogs, 1/2 the time they buy out fords inventory so it's a motorcraft part in a moog box.
(had this happen for my ranger and a mustang, not needed to yet on the lightning)
Old Jul 6, 2006 | 09:47 AM
Silver_2000's Avatar
Not Found
The requested URL was not found on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
Apache/1.3.26 Server at www.timskelton.com Port 80
Old Jul 6, 2006 | 09:49 AM
I love it when they list 6 part numbers that are ALL supposed to be for F150s and there is NO description of the difference between them
Old Jul 6, 2006 | 10:12 AM
Definitely not true for Gen2s. The stock ball joints are not greaseable and of obviously lower quality than the referenced Moog parts. Additionally, the upper ball joints are not replaceable. Moog makes a replacement UCA with a replaceable ball joint.
Old Jul 6, 2006 | 10:13 AM
Originally Posted by Silver_2000
The URL just had a period at the end.
Period removed. Balance is restored to the universe.
Old Jul 6, 2006 | 10:14 AM
The Web page that I reference has correct part #s for all of the ball joints and steering linkages.
Rockauto.com makes ordering this stuff easy. They have menu trees that you can use to drill right down to the correct parts, then just check the box.
Old Jul 6, 2006 | 10:42 AM
bnehila's Avatar
There is 5 different options for uppers but the one lower listed is for gen 1
Old Jul 6, 2006 | 10:50 AM
Flash's Avatar
And the factory sized UCA Prothane bushings fit the Moog uppers?
Old Jul 6, 2006 | 11:33 AM
l-menace's Avatar
I'm guessing the lowering kit didn't have shims to keep the correct pinion angle of the driveshaft and ate up the U-joint.
you'll have to fix that BEFORE installing new parts, or you'll be back in the same position very soon.... constantly replacing U-joints.
Old Jul 6, 2006 | 01:01 PM
SVT F15O's Avatar
I thought we were talking about Ball Joints here.........
Old Jul 6, 2006 | 04:56 PM
pitstain's Avatar
