Question for those with aftermarket dual exhaust
I had my local muffler shop install 2/2 chamber Flowmasters on my L. It sounds great but I've noticed a loss in power in the mid to high range. They did not install a crossover pipe. Did you guys go with any type of crossover pipe ('X' or 'H')? The other thing I noticed is that they put on Flowmasters with 2.25" dia inlets and outlets and adapters. I know our L's have 2.5" dia exhaust pipe. I did not save the stock muffler so I don't know if the L came with 2.25" dia inlets and outlets with adapters. Could this imposed restriction be contributing to the loss in power? Thanks.
Red '00 Lightning
Super Whites
Airaid FIPK
2/2 Chamber Flowmasters
******* X2000 (on order)
BedRug (on order)
Invinca-Shield (on order)
WetOkole Seat Covers (on order)
[This message has been edited by NsTiG8r (edited 06-16-2000).]
Red '00 Lightning
Super Whites
Airaid FIPK
BedRug (on order)
Yes I think it is causing a problem. They should have used the right mufflers without adapters. And, the lack of a cross over will cause a loss of horse power regardless of whatever else you do to your exhaust, unless of course you are running open headers.
I put a Borla cat-back on my L and it had no noticeable impact on low end torque, and it seems to have helped the upper end. I did not do any dyno testing in case anyone is wondering.
The stock muffler has no adapters of any kind. It is a straight slip fit onto the head pipes, and the tailpipes are welded directly to the muffler.
Tundra: I think he means the bent piping leading to the ceramic tips is welded, actually part of the muffler.
NsTiG8r: The piping is 2.5". They need to put the right mufflers on, the 2.5" in/2.5"out.
Red '00 Lightning,
Adopted 4/19/00,
Power Surge Performance enhanced,
Sound effects provided by Flowmaster,
Track time pending...
Red '00 Lightning,
Adopted 4/19/00,
