Motor Questions for the PRO'S
Old Jun 24, 2006 | 12:40 AM
black knight's Avatar
I was wondering what was the sensor in the center of the block was?, i think it is a knock sensor! and what about the sensor on the side of the drivers side head on the inside is that the same thing? What about the oil pump. i bought the high volume oil pump from ford racing. i was wondering will it fit the 5.4. i think it will but not to sure also it came with a new pick-up tub, do i us it or do i use the old one or it makes no diffrence? One last question will crower stage 3 cams fit a 18cc dish piston with no clearence issues?
Old Jun 24, 2006 | 07:50 AM
ShockTherapy's Avatar
The sensor on the inside of the head is a cylinder head temp sensor. The oil pump you bought will work, and the cams you got will work with 18cc dish pistons as well.
Old Jun 24, 2006 | 08:51 PM
What about the sensor in the middle of the block and do i use the oil pick up tube that came with the new oil pump or do i reuse the old on that came off the motor the first time?
Old Jun 24, 2006 | 11:13 PM
Stl01SVT's Avatar
It sounds to me like you are just throwing parts together, and hoping they work. I hope this is not the case.
-Mike
Old Jun 24, 2006 | 11:30 PM
-Mike
Trust me i am not just throwning parts together. i have never really messed with mod motor stuff so thats why i am asking
Old Jun 25, 2006 | 12:36 AM
Bad as L's Avatar
You have to use the high volume pickup tube that cam with the pump and no it wont fit block/pan without some work....you will have to remove or trim a splash sheild and then the splash baffle in the pan will have to be "adjusted" so the pan will go on and even then I still don't like the way it fits.
Then sensor in the valley is a knock sensor and it is not used by the computer however I think you should leave it plugged in.
Old Jun 25, 2006 | 09:56 AM
NCsvt2003L's Avatar
18cc dish piston--what Compression are you planning on running exactly?
Most guys use 14 and a lot are using 12 now.
Old Jun 25, 2006 | 04:30 PM
Thanks for the info
Old Jun 25, 2006 | 04:36 PM
Well i am not trying to run alot of compression just alittle bit over stock, i do drive my truck everyday, befor it blew it, it was making 18 psi and i plan to make 20 or just a little bit more when i am all said and done, i am just looking forward to haveing a save little modmotor that can take a good beating with out a wimper and still be able to drive it everyday like it was befor. I havent drove my L in 6 months and it is killing me
