OBII code P0175...
Old Jul 12, 2006 | 08:54 PM
Nintova's Avatar
Originally Posted by Odin's Wrath
Still haven't found out what's causing this. I had a diagnostic ran at the dealership. Nothing's wrong. He said that he's had 3 other trucks in with the same problem, and all of them had been reflashed. (Different tuners than mine.) I've been suspecting the tune all along; but, didn't want to go there without checking eveything else.
I'm waiting for a tune now from another tuner to test out this theory. Apparently, I'm pretty far down on the waiting list for a retune though. Still open to suggestions.
The dealership said mine was carbon as soon as I called and explained the problem. They had seen a couple other L's with the same issue. This is a common problem with the 5.4 in general. We have an all Ford fleet at my work and everything with a 5.4 that we have has had a carbon builtup issue at some point. Also these are not treated gently, these are EMS vehicals and are pushed pretty hard, probably harder then most here push their trucks.
Old Aug 12, 2006 | 03:29 PM
Odin's Wrath's Avatar
The decarb didn't work; but, running a way too lean tune for a few miles seems to have cured the problem. (Read bad detonation on the new tune.) I put the old tune back in, and no more codes for almost 3 weeks now. Looks like I needed extreme measures to get the carbon burned off.
Old Aug 14, 2006 | 08:27 AM
1BADTK's Avatar
Are you running longtubes?
Old Aug 14, 2006 | 05:57 PM
yup.
Old Aug 14, 2006 | 07:31 PM
jarmstro's Avatar
Here is everything you wanted to know about P0175 for what it's worth.
http://www.obd-codes.com/trouble_cod...gen-sensor.php
Old Aug 14, 2006 | 07:40 PM
