Sub Box?
Old Jun 2, 2006 | 07:32 PM
MicLightning's Avatar
Sub Box?
yes i searched too, came back with 235 pages, im not looking through them all.
I want to build my own sub box for behind the seats in the L, put a 10" sub behind each seat. I plan on using JL's if that makes a difference in the box size?
could someone give me all the dimensions of the box, and I mean ALL
also i was told to use 3/4" MDF board, wood glue all joints and use drywall type screw for holding the subs in. Is this all correct?
I figured some of you audio guys might know.
Thanks.
-Sean
Old Jun 2, 2006 | 08:07 PM
Nintova's Avatar
I am running a setup like you want with 2 10w3's. I can get you the outer dimensions, but since I didnt build the boxes, I'm not sure how think the sides are.
Old Jun 2, 2006 | 08:10 PM
Hostile03SVT's Avatar
Sean, PM sent...
Old Jun 2, 2006 | 08:19 PM
id appreciate the outer dimensions, thats all i really need. but Ill need them all, bottom front to back, bottom side to side, the front height, the back height, the top front to back and top side to side. (top side to side and bottom side to side should be equal)
Thanks in advance if you are able to get them for me
Old Jun 2, 2006 | 08:22 PM
Originally Posted by Hostile03SVT
Sean, PM sent...
replied
Old Jun 2, 2006 | 08:33 PM
Originally Posted by MicLightning
replied
replied
Old Jun 2, 2006 | 08:43 PM
Coldie's Avatar
Just buy a thunderform...
Old Jun 2, 2006 | 11:19 PM
MaxTorque02's Avatar
Thunderforms are cheaper boxes and for the best sound it's best to go with an MDF or fiberglass enclosure. If you're not into the best sound and want the easiest route then a Thunderform makes a good choice.
