Narrowed nitrous issue down to TPS
Old Jun 1, 2006 | 05:29 PM
halflife's Avatar
Narrowed it down to my TPS. I think it is bad. I been trying to figure out where it went wrong. There is power everywhere there is supposed to me. I jumped the TPS and the selenoids worked, so it is not them. There is power going into the TPS because the red light will go on so the red wire is hooked correctly, when I move the throttle to 100% the red light goes on so the white wire is hooked up correctly. I used the screw that I have the black ground wire grounded to as the ground to check my volt meter and that worked so the black wire is hooked up correctly. The only thing is the pink wire is not sending the signal.
Can anything cause this other than the unit being no good?
Old Jun 1, 2006 | 08:37 PM
fullboogie's Avatar
Sounds like you found your gremlin. Keep us updated.
