Supercooler Rusting
Supercooler Rusting
I made my own supercooler with regular steel. I made it fit under the hood where my washer fuild was. The top completely opens up and the copper coil is inside. I sprayed the inside with a stop rust primere and painted it with a high temp engine paint. When I filled it up with water it still rust the inside of the box. Does anyone know how to stop it from rusting. Maybe another kind of liquid mixed with water or some other kind of spray on rust stopper. I also made a hole in the box for my washer fuild motor and it works but rusty water doesn't clean to well. Any help would be nice.
protecting against rust in a gas tank and protecting against rust that deals with engine coolant has to be different. i dont know if gasoline has more rust inhibitors than antifreeze.
i would look into having it sand blasted and powdercoated. or have it sand blasted and use an expoxy paint. you could even check with people that do ceramic coatings and see if that would work and hold up to anti freeze.
i would think aluminum or a 300 grade stainless steel would be the metals for the job.
Originally Posted by Tim Skelton
