pull carrier bearings?
Old May 24, 2006 | 12:40 PM
Slick_Sammy's Avatar
Has anybody had success in pulling the carrier bearings off their stock eaton to put a new diff in? I want to reuse my carrier bearings.... yeah I know, replace them, blah blah, but not at 9800 miles... I will reuse if I can. Can you get a 3 jaw puller on them? Putting a true trac in, any help appreciated. Thanks!
Old May 24, 2006 | 07:07 PM
Sharpshooter's Avatar
The 3 jaw puller might get em. I would try using a machine shop. I didn't have a press so they installed my new bearings on my tru trac.
The new bearings were ~70 dollars, so if the machine shop only charges you 25 to swap bearings you saved a few dollars.
good luck.
Old May 24, 2006 | 07:28 PM
bglanden's Avatar
Buy the new bearing's, put them in your oven and heat them to @ 250-300 degree's, they should fall onto the new unit!
PS, use gloves to pick them up!!
Bryan
