HIGH RISK>>>>?????
Old May 28, 2000 | 04:42 PM
PFA's Avatar
PFA
Question HIGH RISK>>>>?????
Did you happen to get that spec on the studs for me? Thanks
Or if anybody else knows....Is the 12mm and 14mm have the same size spline (the part that holds the stud in)?
PFA
'99 WHITE LIGHTNIN'
#0873--1 of 866--
RHINO, Soft cover, LoJack, Valentine 1, Mobil 1
Phantom Boost gauge-#5707
Phantom Water temp. gauge-#5737--not in yet
Dual pod for pillar-#15303--not in yet
Plasma Super White headlight and foglight bulbs
2000 Mercury Villager Sport
Old May 29, 2000 | 08:00 AM
LightningKid's Avatar
Post
PFA, from what I have seen at work, they are proportionally larger on expy. and F150.
Are you going to try to do the install?
Old May 29, 2000 | 11:32 AM
PFA's Avatar
PFA
Post
Lightningkid,
I have a chance to change over to the 2000 L wheels at no charge (new). I just need to know if the studs will fit into the current holes. If I have to I may drill them out, or better yet have them drilled out at work.
PS I got your e-mail, I'll talk to ya later!
Old May 29, 2000 | 02:14 PM
Thumbs up
Sounds like a deal not to pass up
Old May 29, 2000 | 03:18 PM
PFA's Avatar
PFA
Post
Pacecar18
Thanks for the link. I understand it can be alot of work but the question still stands (unless I didn't catch it on the other post, please correct me), are the holes the same size on the rotors and axle ends for the studs to go through?
Thanks for the feedback!
Old May 29, 2000 | 04:32 PM
BABolt's Avatar
Talking
Hi Wayne
No.
Old May 29, 2000 | 05:17 PM
PFA's Avatar
PFA
Post
Hi BABolt
OKAY. Thanks
Old May 30, 2000 | 12:29 AM
Pacecar18's Avatar
Post
PFA
Check for your answer here in this message I started!
https://www.f150online.com/f150board...ML/003402.html
Take it easy!
