Sharpshooter won't be happy.
Old May 23, 2006 | 06:59 PM
Lightning LA's Avatar
That is by far going to be the best looking set up you've done to date,i can't wait to see it all done and mounted up with gauges!
Old May 23, 2006 | 07:31 PM
Neal's Avatar
HI!... Because of TAMPA and SHARPSHOOTER I also did this mod a few months back. I went with a 3 gauge set-up though. Again, thanks for the help guys!
Old May 23, 2006 | 09:23 PM
NCsvt2003L's Avatar
That looks good!!
Old May 24, 2006 | 08:49 AM
brahmus's Avatar
Originally Posted by TampaBlack99
Adhesion promoter is only needed when your too lazy to actually sand the part. I usually sand all my parts with 220 grit sandpaper which makes it uneccessary. Just make sure to tack cloth the part before you paint. Painting over dust in never a good idea.
Ok, understood!
What are you tacking with? Is there a certain cloth that should be used as not to leave threads or other contaminents? Acetone, thinner, alcohol??
Old May 24, 2006 | 10:46 AM
TampaBlack99's Avatar
Go to any auto parts store. There sticky cheese cloths that work great, they cost about a $1. Will be located near the bondo.
Old May 25, 2006 | 09:43 AM
Final pics.
Already starting on the new fully recessed version.
Old May 25, 2006 | 10:22 AM
brahmus's Avatar
As usual great work!!!
Old May 25, 2006 | 11:36 AM
raider's Avatar
Tampa you do great work
Old May 25, 2006 | 11:38 AM
brahmus's Avatar
You going to offer this, maybe on an exchange deal? Or are you keeping it all you yourself?? haha. With the dual surfboard pod I need a good place to put 2 more gauges.
Old May 26, 2006 | 11:40 AM
brahmus's Avatar
Another question for you. I picked up a can of SEM texture coating and I'm practicing with it. It sprays more of a stream than a mist. What is the trick to get a good even coat?
