should i do upper or lower pulley?
Old May 12, 2006 | 02:56 AM
twizzler93tt's Avatar
ive been reading alot of threads about pulleys and i thought maybe it would help me make my decision but it didnt ive noticed alot of people have went with the upper and alot with the lower what should i do? im thinking about getting the 2.77" Upper Pulley Kit from razor's edge for 129$ and from what ive read ill probably need to get the idler pulley so i dont get slippage right?
the only lower kits i can find are all rather pricy, but i would get the same amount of boost from doing either right?
also is a 2lb pulley ok to run with a stock tune? i wont be able to get the chip or programmer for while.
thanks,
chris
Old May 12, 2006 | 09:04 AM
The Swede's Avatar
TRUCK OF THE YEAR - 2010
Lower pulley !
Old May 12, 2006 | 09:13 AM
Dbl G's Avatar
Yes a two pound is safe,, the EEC/ECU is set up to learn or re-teach it's self so to speak. Just drive out of boost for a couple hundred miles, normal traffic and you should be fine.
Old May 12, 2006 | 10:09 AM
halcyon's Avatar
replacing the heavier stock lower may offer benifits too.
Old May 12, 2006 | 10:25 AM
Dbl G's Avatar
Why yes it will,,less rotating mass
Old May 12, 2006 | 11:20 AM
Tim Skelton's Avatar
The only reason to run a smaller upper pulley is when you are out of lower pulley options.
Smaller pulley = more belt slip
More belt slip = less boost, more belt wear and dust
Old May 12, 2006 | 03:30 PM
thanks guys like i said i wasnt sure but now i think thats the way i am going to go anyone have a good place to order a lower pulley from thats not to $$$?
Old May 12, 2006 | 03:35 PM
Ct.TOPGUN's Avatar
Try Lightning Force Performance. Good pricing!
Old May 12, 2006 | 03:47 PM
l-menace's Avatar
agreed... get the interchangable lower pulley.. that way upgrading in the future is easier.
Old May 13, 2006 | 09:56 AM
Dbl G's Avatar
Much better service here..
http://www.chickenears.com/metco_lower_pulley.htm
Old May 14, 2006 | 01:20 AM
SILVERLIGHTNING's Avatar
+1
