What tranny cooler are you using?
Old May 1, 2006 | 11:51 AM
fullboogie's Avatar
I've been datalogging my tranny temps lately through SCT software to my laptop. What I'm seeing is up to 190 degrees in 90 degree weather - 175 to 180 in 80 degree weather. Seems rather high to me, so I want to add a tranny cooler.
What is everyone using? Don't want to spend nearly $300 for the LFP one. I'm also a little hesitant to use the F250 one because it appears to cover most of the radiator - anybody use this one without any adverse affects on engine temps?
How about the B&M unit? I've seen a few initial posts on these, but no follow ups on the install.
I'm looking for a plug and play, without too much fuss. Any thoughts appreciated.
Old May 1, 2006 | 01:18 PM
The Swede's Avatar
TRUCK OF THE YEAR - 2010
I use a LFP !
The B&M once are crap.
Old May 1, 2006 | 02:17 PM
Hostile03SVT's Avatar
i havent upgraded the cooler on my lightning yet. although i have used the B&M supercooler on my mustangs chevelle camaro and bronco.. all these Vehicles ive used them on they worked flawless.. they are far from crap...
Old May 1, 2006 | 09:04 PM
SVTPIRATES's Avatar
I don't know how much they cost but the Super Duty trans cooler is bigger. You could probably find one at a good price.
Old May 2, 2006 | 05:36 PM
Smok'n L's Avatar
i got the ford heavy duty van/mobile home cooler it looks just like the stock one but bigger, its a direct bolt on replacment of the original.(thats what i like) i dont have a guage yet to tell u what the temps r, sorry? i had the lfp and sent it back, nice piece but didnt have time to mess w/the install?
later
Old May 2, 2006 | 05:50 PM
brain bypass's Avatar
last time i checked, around $100
Old May 2, 2006 | 06:29 PM
fullboogie's Avatar
Thanks guys. But as indicated in my first post, I have concerns over the super duty cooler covering 2/3 of the radiator. I'm already sort of on the edge of radiator cooling with an electric fan.
The B&M's with integral cooling fan are starting to look real nice.
Old May 2, 2006 | 07:25 PM
Ct.TOPGUN's Avatar
Moroso makes a couple of frame mounted heat sink style coolers. Check them out.
Old May 3, 2006 | 06:27 AM
Daves00L's Avatar
I have had the Factory Tech Cooler inline with the stock cooler for 2 years. i also have a trans temp gage and have datalogged via Predator. on hot days in the 85-90 range, i never exceed 165 degrees or so. in the spring/fall, it's always 150 degrees. i used to be in the 180 range in hotter weather, so i'd say it has cut at least 15 degrees.
does not cover much of radiator (about 12x12). very easy to install/mount with included stainless hoses.
Dave
2001L
Old May 3, 2006 | 07:04 AM
LightningToGo's Avatar
I also have the Factory Tech Cooler.
Old May 3, 2006 | 09:53 AM
Certified Drunk's Avatar
I have had the F250 cooler for two year and never seen any change in the coolant temp.
Old May 3, 2006 | 02:42 PM
Johnny AC's Avatar
B&M with Fan
I think I'm going with the B&M unit with a thermo-controlled fan. It's called their Hi-Tek fan, 2 sizes and I'm getting the larger one. I'm mounting mine out back somewhere.
Old May 3, 2006 | 04:04 PM
fullboogie's Avatar
Thanks for all the input. Sounds like no problems installing the factory tech cooler, which was a concern.
