Calling Sycoholic HELP need info SYSTEM 4
Old May 19, 2000 | 06:16 PM
Wiley C's Avatar
Question Calling Sycoholic HELP need info SYSTEM 4
I’ve been having a problem getting the right info from the dealer ships around here on which Security system I needed for a SVT F-150 00 Lightning. I called CODE ALARM and they said I need the SYSTEM 4. They give me a part # of F3AZ19A361C do you know if this is the right info and does the SYSTEM 4 come with a wiring harness and every thing I need to install It.
Thanks Ted
Old May 19, 2000 | 11:16 PM
Sycoholic's Avatar
Cool
If you have factory keyless entry you need the System 4 alarm. It comes complete with everything you'll need. Even comes with some butt connectors. Comes with a wiring chart, if the chart doesn't cover your year, you can call 1800fordkey for the right one, as well as any tech questions. It is relatively easy to install these. They have the starter kill, led/valet button, override button, dual stage shock sensor, module, wiring harness, zip ties, window stickers too. Nice units, and relatively easy to install. Should take a couple hours. Time consuming, not hard.... First one I ever did took me 3 hours.
1997 F-150, 4.6, automatic, Dark Toreador Red, Supercab, Flareside, 4X4 Off-Road, Towing Package, Ford hvy dty rubber floor mats, Kenwood 10-disk cd changer, Kenwood am/fm cassette head unit, Ford bugshield, Chrome Grizzly Wrap Around Push Bar with 2 KC 100w Daylighters, Ventshades, Ford bedliner, Lund Premier tonneau cover, cab and bed professionally undercoated, Code Alarm Sure Start RVS remote starter, Ford alarm, Realistic CB with Wilson Little Wil antenna and Astatic power mic, ported MAF sensor, and Lots of TLC!! (Besides being an F-150 nut, I am a Ford auto technician.)
Old May 20, 2000 | 09:09 AM
Wiley C's Avatar
Thumbs up
Sycoholic
I'll give it a go. The System 4 looks like a pretty good alarm. Thank's for the info.
Ted
