traction bars for towing
Old Apr 27, 2006 | 11:38 PM
Slick_Sammy's Avatar
which bars would work best for the frequent drag strip use and occasional towing duties? I was thinking maybe the Metco track link style but really like the simplicity of the long bars. I've asked this a couple times and searched, can't find much or any info. any input appreciated. pros and cons of each for towing purposes. thanks.
Old Apr 28, 2006 | 01:38 AM
bobby beige's Avatar
I've been mulling this thought over too,
Do I spend the big bucks on the JLP or PSP bars?
Or are the Truck Trac slapper bars going to be enough to do the job?
Or do I cheap out and simply go for the Lakewood setup?
I only have minor mods (intake, exhaust, chip) but with the new slicks, some safety requirements ($$$ driveshafts) are definatly required.
Old Apr 28, 2006 | 01:52 PM
i've asked this about 4 times on different forums over the last year and no one has given me any kind of worthwhile feedback. I guess no one knows?Oh well. Guess I'll call some vendors.
Old Apr 28, 2006 | 03:03 PM
Don's Bolt's Avatar
I have the Rancho 58 inch traction bars, and in my opinion they are the best traction bars for the drag strip. When I used to have a SVT Focus I towed it 300 miles and never knew it was back there.
Old Apr 28, 2006 | 10:56 PM
Certified Drunk's Avatar
I've had the JLP for 3 years, No problems
Old Apr 28, 2006 | 11:10 PM
thanks. what i'm gathering is it doesn't really matter about towing or bars may even help stabalize and stiffen the suspension for towing. anyway, i bit the bullet and got the Metcos figuring their adjustability might be nice, so we'll see how it goes.
Old Apr 28, 2006 | 11:17 PM
Tim Skelton's Avatar
You should be fine. The only bars that might be problematic are slappers, because they might be resting on the springs when loaded down.
I recommend helper airbags. They massively improve the load-carrying capability.
Old Apr 28, 2006 | 11:20 PM
right tim, i ruled the slappers out. since mine is an 03 the extra rear spring rating is perfect for what i tow so i am good to go. if it sagged more i'd definitely put some air bags under there.
Old Apr 29, 2006 | 01:59 PM
noah's Avatar
Ok..thats one of the reasons I held off on traction bars due to the fact that I tow my 3000lb boat. But from what yall are sayin....I guess if I went ahead and got the JLP bars i wanted then I would be fine.
