Need Help
Old Apr 26, 2006 | 10:41 AM
LightningPower3's Avatar
Question Need Help!!!!!!!!!!!!!!!!!!!!!!!!!
Hey guys. My lightning has 50k miles on it and a couple days ago it started acting a little funny. It does it when it wants to aparently but sometimes when i start it up, the rpm needle gets stuck right above 1k on it's descent and makes a womp womp womp sound. Also the noise occurs sometime when i amp driving after it's reved up a past about 2k rpm and sometimes when i put the truck in reverse. I discovered that the sound was coming from the intake and only got louder when i disconnected the air box. I ordered a new instake because I also discoved the filter was horrible. Anyone happen to know what causes this sound or have experienced this before??? Thanks
Old Apr 26, 2006 | 02:03 PM
promodlightning's Avatar
Sounds like your idle air speed motor on side of plenum is bad.
Old Apr 26, 2006 | 06:15 PM
it idles fine
Old Apr 26, 2006 | 07:16 PM
BriteRed20s's Avatar
Disconnect the IAC cable when its making the noise, If it's that the noise will stop. If you need a new one get it from Ford and not from aftermarket supplier.
Old Apr 26, 2006 | 10:51 PM
i disconnected all of the plugs on the intake and the noise kept comin. i have a k&n intake on the way, and i'm gonna have a mechanic look at it. i'm stumped
Old Apr 26, 2006 | 11:26 PM
BLACKBOLT02's Avatar
It could be your fuel pressure regulater or you could have too much carbon build-up in your intake. I have a 93' F-150 that did the same thing that you are talking about. Best of luck.
