Optimum Chip (PSP) Settings
Old May 16, 2000 | 05:35 PM
LSTORM's Avatar
Question Optimum Chip (PSP) Settings
I just ordered Sal's PSP Chip, and was wondering from all you guys that have already done your homework and research what the best settings were.
Here is my order info:
2000 Ford Lightning
- Year - 2000
- Engine Size - 5.4L
- Injector Size - ???
- Fuel Pressure Setting Currently Used - ???
- With Cats - Yes
- Smog Pump Used - ???
- EGR Used - ???
- Heads - Stock
- Cam info - Brand - Stock
- Octane Rating of fuel to be used - 89-93-???
- Fuel Economy - (Good,fair doesn't matter)-???
- Preferred rev limit - ???
- Remove Rev Limit - (yes,no) - ??
- Wide open throttle shift points:
1-2 - ???
2-3 - ???
3-4 - ???
- Transmission shift firmness at WOT:
(stock, firmer, much firmer) - ???
- Transmission shift firmness at part throttle:
Power Added Vehicle:
- make and model of supercharger,nos kit: factory supercharger - (Eaton)
- Factory boost level - 10 psi
- PSI that boost gage reads at :
2000 rpm - ???
3000 rpm - ???
4000 rpm - ???
5000 rpm - ???
- intercooler - yes
- FMU calibration (ratio) - ???
- rpm you first see boost - ??? how much - ??
- Max boost reading - 10 psi at ??? rpm
Thank you in advance for any and all advice.
