Tranny trouble need help!
Old May 14, 2000 | 05:42 PM
Burninout101's Avatar
Post Tranny trouble need help!
I think. When i go to shift the truck from P to D or R it will pop really loud when it gets in gear(no im not moving in sitting still when i shift) only dose it every now and then, also I can turn the truck on and about 3 sec after i turn it on theres a loud grinding sound and a pop ( like when you dont use enough clutch and grind a gear on a standard) its about half a second long. It also shifts late or ealry every now and then and sometimes it feels like the tanny is slipping buti have been told that these tranys can not slip because of the way there built. So is there somthing wron and if so what? im not happy about this at all.
Justen
[This message has been edited by Burninout101 (edited 05-14-2000).]
Old May 14, 2000 | 07:22 PM
2000Silverbulletonorder's Avatar
Post
Justen,
Check you transmission fluid, both level and color/smell. It sounds worth having a dealer tech check out.
