Calling H8 2 W8
Old May 6, 2000 | 07:37 PM
blackbolt's Avatar
Post Calling H8 2 W8
Hey Rob,
Followed your instructions to the letter when trying to setup the driving lights to come on without pulling the switch out....
One major problem, the yellow wire that you mention in the post is not on the left side of the the switch, it is in the middle connector of the three and after finding a suitable ground and then Teeing the yellow wire and attaching a switch, the unit did not work, also noted that the whole switch unit(metal parts)is hot (tested with 12 volt tester)...I know yours works cause I've seen them and have pics of it...but could you tell me which wire location (connector wise) to use....any help would be appreciated....
Note: if anybody else can help that would be appreciated.....
Old May 7, 2000 | 08:04 PM
blackbolt's Avatar
Question
back to the top
