Code P1639 Vehicle ID Block Not Programmed Or Corrupt (Ford)
Old Apr 7, 2006 | 11:10 AM
tallimeca's Avatar
Thumbs down Code P1639 Vehicle ID Block Not Programmed Or Corrupt (Ford)
A fellow board member keeps getting this code. He has had problems getting state inspections for a couple years now because of the P1000 or P1001 code that you get when a full drive cycle hasn't been complete, and it only started happening when he got his predator. I used that same predator to pull codes on my truck one day then I started getting that same cycle code and couldn't get rid of it...in fact, I think I still have it and need to check because i'm do for inspection.
Now this new code appeared on his truck. Any info??
Old Apr 7, 2006 | 12:57 PM
unclemole's Avatar
Corrupt PCM files.
1. Don't use that predator.
2. Contact Diablo.
3. Reprogram PCM.
Old Jun 21, 2012 | 11:49 PM
mcliff's Avatar
2000 F150, 5.4L
I need some help with this P1639 code because my check engine light is on I will fail the California Smog Test with the light on. I can make it disappear by clearing it with my code reader, however when I turn the engine off and start, the check engine light is back on.
How can I solve this problem without going to the dealer? Anyone out there run into this problem before?
Thanks.
