WOT 1st to 2nd Shift.... hesitation
I have now installed Sal's PSP filter kit and hoped this problem would go away. WOT shifts when going into to second gear show a sign of hesitation and drop of rpm .... then catches up and screams again. Anyone had similar problems and a solution w/o a new chip?
Ron B.
Kathleen, GA.
*Red 2000 Lightning
*ARE LSII
*Speed Liner (color matched)
*PSP Filter and Outer Ware
*Bear Tracker
*Valentine Radar Detector
*Dual Flow Masters Delta 50s
*Tinted Windows
*Lund color matched bug deflector
*4 Pioneer TS-A6895 speakers
Ron B.
Kathleen, GA.
*Red 2000 Lightning
*ARE LSII
*Bear Tracker
*Tinted Windows
I've also noticed this on mine occasionally on 1-2 shift and 2-3 shift. Not every time however. It seems like lag coming from the supercharger. I'm also thinking the electronics may be causing part of the problem. This being the first supercharged vehicle I have owned, I really do not know what the norm is.
[This message has been edited by Y2K Bolt (edited 05-06-2000).]
Hey Ron, Sal here. What you are describing is the normal operation of the stock PCM. At WOT, it drops cylinders. This results in what feels like a "pause" or "lag" in between shifts. Yes, it is extremely annoying, and was the first thing I worked on for the new trucks. As previously stated, our chips eliminate this.
SAL
13.209@104.3mph
Power Surge Performance 99 Lightning Chip and Filter Kit, full Bassani Exhaust, Nitto Extreme Drags
PowerSurgePerf@aol.com
SAL
13.209@104.3mph
With Sal's chip my truck pulls like a locomotive from 0 to 140 mph. No hesitation, no flat spots, no pinging, just pure acceleration! Make certain that your chip is in performance mode!
adp
#1530
Black '99
adp
#1530
Black '99
Make shure that the chip connection is clean. I saw it said alot on this site. When Bill M gave me his chip to use, he told me again. But took me one little trip down road, to find out that I did not do a good job. It whent to shift from first to second, and paused(lost power),then went on. My son was riding with me and he said what was that. My seven year old new that it wasn't right. Recleaned connection and shift problem was gone. Only time I've had a shift problem. But if yours was doing it before chip, you may have other problem(s). If it is pausing or really losing power, you may need to take to dealer for them check. With out the chip in, I've always been able to her pcm drop cyl as it shifts(at WOT), but no powerloss.
99.5 Black Lighting
CD Changer,Tow Pack,Ford Bed Liner,2In Drop Shackles ,Tinted Windows,4 Rear Stoplights
2000 Mustang GT
Convertible,Performance Red,Black Top,5 Speed,
Cobra R Wheels,BFG Tires, Bassani X Pipe, Flowmaster Mufflers / Stock tips , K+N Filter With Air Silencer Removed , FMS 4.10 gears
99.5 Black Lighting
2000 Mustang GT
