Ported box can be done in the L!
Old Apr 4, 2006 | 12:02 PM
TampaBlack99's Avatar
Almost half done with mine. This will be for a JL 10w3 initially which needs 1.00 cu ft of internal volume. I will then install 2 braces to get the volume down to 0.75 for a future 10w6. Port will fire against the passenger side of the cab, sub will fire down behind the driver. I think the guy with the 10w7 is a sealed box, I could be wrong. It's hard to tell from his pics.
Total volume of the 3/4" mdf box is 1.3 cu ft (before sub and port volume subtractions).
Old Apr 4, 2006 | 12:39 PM
brain bypass's Avatar
i have one in mine that the gross volume is 1.5 cu. ft., with a recessed amp rack. net volume is like 1.4 for my orion hcca 10d. it fits, but it uses ALL the space back there
Old Apr 4, 2006 | 12:41 PM
I was trying to only use the space where the tool box is. Really wanted a box that was low and out of site. I also have a ton of black painted parts I don't want to cover.
Gross volume for this box is 1.3 cu ft. When the port and sub volume is subtracted I get 0.913 cu ft.
Old Apr 4, 2006 | 12:55 PM
it is out of site when the seats are in their normal position. it actually makes a nice shelf to set stuff on.
Old Apr 4, 2006 | 01:03 PM
Jakkle5's Avatar
I dont see what special about this? I did a ported kicker solo-baric 10" L7 about a year ago. It's not that hard to do, you just have to like sloppy bass.
Old Apr 4, 2006 | 02:16 PM
Bootbox's Avatar
Looks awesome Tampa, can't wait to see the final box. I'm sure it will be stunning like the rest of your projects.
I'm in the process of planning a (2) 12" blowthru setup. Anyone done this on their Lightning?
Old Apr 4, 2006 | 02:40 PM
Thanks, if this does'nt work a blow thru is my next step.
Old Apr 4, 2006 | 08:04 PM
SVTPIRATES's Avatar
Blow thru? do you mean that the subs will be in the bed and the bass will travel thru a hole conected to the bed and the cab?
Old Apr 4, 2006 | 08:51 PM
Lumadar's Avatar
Exactly
Old Apr 5, 2006 | 02:07 PM
SVTPIRATES's Avatar
wow what a guess.
