Spark plugs, heat ranges, thermal transfer and you
Sometimes the idea bulb goes off when the Pollocks care to replace it, and I feel compelled to share. I would like to state in advance that I've searched for this topic, and couldn't find any precedent from others on this board.
Most of you should know how spark plugs work and how they are rated. They absorb some heat energy from combustion, maintain a portion of that heat to keep the plug clean of sooty deposits and dump the rest to the cylinder head through the surface area of the plug's threads and the head's threads, and a plug gasket/bevelled contact area at the top.
On our vehicles, at least for those of us with 4 or > threaded heads, spark plugs only have the surface area available through the reduced threads, and whatever can be transferred through the plug seal and bevel at the top.
My reasoning is this, when a manufacturer designs a plug for a particular heat rating, especially for our application (5.4L motor), I do not believe that they are taking in account for the lack of surface area in the 4 thread stock heads. Ford very well might, however NGK, Denso and others may be rating a plug assuming that the head has full threads to the top.
In addition to that issue, I hypothesise that in a high boost, high heat output situation, a plug of a signifigantly cooler heat range may not be any more effective than that of a warmer plug due to the the lack of thermal transfer area. In my own experience, I have seen detonation issues under high boost, within the acceptable A/F ratio and well below "dangerous" IAT2 conditions. I believe a cooler plug can be prone to overheat in 4 thread heads under high-load conditions, even if the plug is rated for that operational heat range. In other words, the "cold range" spark plug, not able to migrate quick thermal heating will become effectivly a glowplug in a 4 threaded head.
The solution, of course would be to install inserts/helicoils or to use the new heads with 8+ threads.
Since this is speculative on my part, I invite tuners, builders and experienced engine techies to comment on this. Perhaps this might help stock head users that have experienced detonation and have not been able to properly deal with it.
I've had concerns about this myself. One significant issue is the addition of inserts or helicoils like you mentioned. You are assuming that adding these will give you the surface contact for additional thermal transfer. I think it is possible that this may be incorrect and you may be doing more harm than good for heat dissipation to the head since the insert material is made from steel, a much worse conductor of heat than the aluminum head material even if you do have more surface contact. How much worse is the question. Is it enough to run a one step colder plug, maybe two steps?
