need snow perf help asap
Old Mar 29, 2006 | 08:38 PM
1 bad bolt's Avatar
i just installed my kit and soon as i started my truck it smoked really bad, the motor boggs and the activation light comes on soon as i touch the gas, i have a 375 spray nozzle in it and tried re-adjusting the settings on the maf controller , can anyone help me please??????
Old Mar 29, 2006 | 10:18 PM
scv8's Avatar
It sounds like you need to set the onset voltage higher.
Old Mar 29, 2006 | 10:32 PM
1 bad bolt's Avatar
i was told by another guy since i have my nozzle in a throttle body spacer and not in the jlp thunder pipe im getting vacumm which is suckin all the juice down, so i need to get a solanoid kit
Old Mar 29, 2006 | 11:12 PM
topqualifier's Avatar
Check to make sure that the onset voltage is high enough. Then check your wiring to see if there is something amiss there causing the pump to kick on automatically. If that's not it you may need to put a check valve inline to prevent siphoning at low throttle.
Old Mar 30, 2006 | 12:37 AM
camcojb's Avatar
If the nozzle is in vacuum like yours, you'll need their solenoid kit. Otherwise it will siphon all the alky out of the tank.
Jody
Old Mar 30, 2006 | 01:49 PM
jarmstro's Avatar
Why don't you just call Snow Performance? I bet they can answer your question
Old Mar 30, 2006 | 02:37 PM
1 bad bolt's Avatar
at the time i did but it was too late in the night and they were closed but i have a solanoid upgrade kit coming overnite for it which should hopefully cure all my problems, by the way camcojb was 100% right on what was causing my problem he knows his stuff , if the air/fuel was set at 11.8 on my new tune is that going to be to low??, i dont have a local speed shop to dyno tune my truck so i have to do mail tune which is a pain to keep getting done. does anyone think it will be ok with a 375 spray nozzle or should it be done to 12.5 ???
Old Mar 30, 2006 | 02:49 PM
camcojb's Avatar
The alky will richen the tune. I would tune it to be safe a/f-wise without the alky, and then not worry about it being richer with it. I don' think you'll feel a power loss and it's safer that way in case the alky ran out at wot.
Jody
Old Mar 30, 2006 | 02:53 PM
1 bad bolt's Avatar
i jsut got my predator back from being re-tuned for the snow kit, so i sohld be ok with what i have now?
Old Mar 30, 2006 | 03:34 PM
camcojb's Avatar
Should be, but the responsibility falls on you to verify that the a/f is correct and it isn't detonating.
Jody
