Computer Goo?
Old Apr 29, 2000 | 01:48 AM
jack77's Avatar
Question Computer Goo?
Anybody know what that clear goo is that coats the computer contacts? It might help some with potential dealer warranty problems. If you could pull the chip and put a new coat of that stuff on before taking it in, you might be able to avoid the whole "you're chip caused the problem" situation.
White 1999 Lightning
Build Date 7-26-99
#2892
Snuglid
Bedrug
Superchip
Member NLOC
Old Apr 29, 2000 | 09:23 AM
4D THNDR's Avatar
Post
The stuff I took off appeared to be like parafin wax. Just melt some and dip the contacts in it is what I would have tried.
Red '00 Lightning,
Adopted 4/19/00,
PSP Filter,
Track time pending...
Old Apr 29, 2000 | 10:29 AM
Silver_2000's Avatar
Post
What I read on Superchips sites was that it was 2 things: laquer on the board from the manufacturing and grease (wax) I guess from the factory. God knows why. If you clean it carefully you can tell youare going through 2 diff materials
Doug
Got Silver 2000 Lightning 2/28/00!!
1st run 13.9 sec 1/4 !!
Doug
Carrollton TX
drbdkb@hotmail.com
Had 87 Turbo Coupe traded for
92 F150 XLT 302, Put K&N Filter, cat back and Chip on 92 Still not enough.
Silver 2000 Lightning, Valentine 1, Snuglid, Bedrug and K&N Filter. Have Sals Chip and Filter on order, cant wait.
Old Apr 29, 2000 | 02:14 PM
Nathan's Avatar
Wink
Ask Wyldman. he knows.
Old Apr 29, 2000 | 06:44 PM
Wyldman's Avatar
Exclamation
The outer layer is called Humiseal, it is an antielemental coating used to moisture proof electronic components in hostile environments. The inner coating is just PC board varnish, & can be a real bear to get cleaned off the contacts. Go slow, be careful and finish your cleaning process w/a soft clean pencil eraser (art gum works real well, too, and isn't as abrasive).
The Wyldman
Old Apr 30, 2000 | 12:29 AM
jack77's Avatar
Post
Thanks Wyldman. Just gathering info just in case there ever is a drivetrain problem. Any sugestions for where to get these products?
Old Apr 30, 2000 | 07:44 PM
Wyldman's Avatar
Post
Jack77,
Humiseal can be had at most electronic component outlets (NOT Radio Shack!) PCB varnish is likely to be had in the same type of place. I don't think the varnish would be necessary, as Humiseal is opaque and if they go to the trouble of scraping off the gook, then they want you bad anyway.
Fun things to know and learn......
The Wyldman
