Lightning block same as 3 valve 5.4?
Old Mar 20, 2006 | 10:37 PM
GoneIn60Seconds's Avatar
Not sure if it possible but i was wondering if the rotating assembly of a Lighning block would work in the new 3 valve 5.4 out of an 05 F-150? Has anyone researched this or done the work before. i want to increase the power with out blowing my bottom out and i cant find stronger parts for my exact engine. Any help would be appreciated!
Old Mar 20, 2006 | 10:40 PM
Unoid's Avatar
you could have just googled the lightning's engine?
But Since i'm nice I'll give you the info you want.
Lightning engine is a low compressiong 2v SOHC 5.4L with an eaton blower.
theres differences
Old Mar 20, 2006 | 11:31 PM
birdy111's Avatar
yeah... I don't see why you coudn't slap 3v heads on an L bottom end, you'd just have to change the intake manifold to the 5.43v design... which means no bolting on the L intake/supercharger. It'd probably be just as cheap to build your 3v and not swap an L shortblock in though... That way you could reliably build it past 450hp too...just an idea
Old Mar 21, 2006 | 07:15 AM
RDY2RAC's Avatar
www.livernoismotorsports.com
give them a call.
internally your block is the same as any other 5.4 block. but i'm not sure the the difference in compression for your 3 valve compared to the 2 valve. you may need a different piston than what everyone else uses on there L's to get the desired CR.
