Interchiller is a real nice piece!
Old Mar 20, 2006 | 04:58 PM
TampaBlack99's Avatar
Just got this in a trade, was suprised on how well the thing is built!
Thing is built from thick azz aluminum!
Old Mar 20, 2006 | 08:50 PM
boomr's Avatar
Who made this, & how much? Looks like a nice piece.
Old Mar 20, 2006 | 10:25 PM
Tim Skelton's Avatar
A clue.
Another clue.
Old Mar 21, 2006 | 05:40 AM
boomr's Avatar
Thanks for the link. The first link work's, the second one states
"Sorry - no matches. Please try some different terms."
Old Mar 21, 2006 | 09:48 AM
It's expensive at $330, I was just suprised at how well it's built.
Old Mar 21, 2006 | 10:58 AM
dirtchicken's Avatar
I would spent the $330 elsewhere.
Old Mar 21, 2006 | 11:16 AM
Shocked's Avatar
SVC Motorsports in Scottsdale, AZ designed and manufactures the InterChiller. www.svcmotorsports.com They tune most of the Lightning's in Arizona.
Old Mar 21, 2006 | 05:01 PM
Fowl's Avatar
Is there any other benefit to the interchiller except for the track cool down.
Old Mar 21, 2006 | 05:46 PM
Mondo1's Avatar
The only reason I don't loke those is if a fan goes bad, your airflow goes down to almost nill, being the shroud is blocking the free flow air. Its eficiency is predicated on the fans moving the air through their own openings.
Old Mar 21, 2006 | 05:59 PM
The same can be said for your radiator.
Old Mar 21, 2006 | 06:02 PM
Errr, well, when would the intercooler water get warm?
If it's uber hot outside (e.g., Arizona).
After a 1/4 mile blast.
During sustained high-boost driving.
Old Mar 21, 2006 | 10:13 PM
Mondo1's Avatar
Not really.There isn't a wall of aluminum blocking my radiator aroung my fan.
Old Mar 21, 2006 | 11:31 PM
From a previous post on this board (not mine):
"Well about that restriction. I did my own testing without the system installed. Cruising on the freeway for 25 miles at 80mph in drive (3rd gear) turning about 3600 rpm. Intake temp on the 2nd IAT sensor (the one in the intake manifold), I had a constant temp of 135 degrees. Then I put the InterChiller system on and did the same run with the fans off. Constant temp of 138 degrees. Then with the fans on, constant temp of 110 degrees. What do you think about your restriction now? Wouldn't you have the same issues with the engine radiator also. It has a shroud too, does it restrict the air flow? No. The fans will spin as the air rushes by them. The best part of this system is the shroud. Because it pulls the air through the whole intercooler, not just where the fans are mounted."
Old Mar 22, 2006 | 10:18 AM
Nice to know it actually works, will post some data soon after the install is done. Plan on using my Nordskog temp gauge with high temp recall to monitor temps in 4 different configurations.
1) OEM Heat Exchanger by itself
2) Dual OEM Heat Exchangers
3) Dual OEM Heat Exchangers with Interchiller
4) Dualy OEM Heat Exchangers, Intechiller and Mister System
Hopefully I'll get much lower than 110 degrees
Old Mar 22, 2006 | 05:56 PM
Mondo1's Avatar
Its hard to believe only a 3 degree increase without the fans on. But the facts seem to be there. I stand corrected.
