motor question
Old Mar 8, 2006 | 12:11 AM
monkeysL's Avatar
motor question
to start off, i'm not a big "engine builder" person but, i just unwrapped the new JLP shortblock i purchased a while back and there is green sticky stuff everywhere (in some bores, underside on crank, rods, and etc.), is this something used when putting it together or what? i hadn't noticed it before on other built engines i've had.
Old Mar 8, 2006 | 12:57 PM
monkeysL's Avatar
nobody any idea to what this might be?
Old Mar 8, 2006 | 01:02 PM
clonetek's Avatar
Did you call/contact JLP to ask them?
Old Mar 8, 2006 | 01:25 PM
JollyGiant's Avatar
It's probably a preservative to prevent corrosion but I would call JLP to be sure.
Old Mar 8, 2006 | 02:14 PM
monkeysL's Avatar
i tried calling and almost crapped when i got a ring the first try only to realize they are closed on wednesdays.......i think i'm to the conclusion its assembly lube but i never knew that much was used until being informed by others
Old Mar 8, 2006 | 04:51 PM
Black02SVTL's Avatar
Like JollyGiant said its most likely an anti-corrosion susbstance.
