Computer Read Out-lets compare notes!
Mine read the same as yours besides the fuel.
I did the check on the gages all moved but the boost gage. Is this what you are gitting?
00 White Lightning
Window Tint
Clear Corners
Sal's filter kit on order
2\2 Chamber Flowmasters
00 White Lightning
Window Tint
Clear Corners
the cracks to the code, are on the same site you found the code. just scroll down some more i think. i tried those out a long time ago. the only ones that prove of any use are the tach and speed. at least to me they were useful.
I've found that the digital speed is about 2-4 mph different then my analog speed... which one would be the most acrruate I wounder, the digital?
Probably be a good way to see how accurate your analog gauges are. Like SVT-TOMMY said, the meanings of the codes are on the same page, just further below.
I like using the digital speedometer or tach...its fun.
Burninout01, looks like your truck was not running when you wrote down the codes right? (tach 0, oil at 255)
