is my PCM damaged?
Old Feb 25, 2006 | 05:58 PM
ixcelr8's Avatar
is my PCM damaged?
truck idles funny dies while driving normal sometimes while idleing if i give it gas it stubbles and hesitates like its out of gas and dies i have check code one day got PO107/P1121 i cleared those codes and the next day checked them again and got all new codes PO460/P1636/P1747
P1636 =aux in/output malfucurer control (inductive sig chip comm error indicates the PCM has lost comm w/the inductive sig chip (PCM damaged)
and a couple other cades indicated a poss PCM damage
any info would be helpful thanks
Old Feb 25, 2006 | 06:49 PM
evo's Avatar
evo
Try resetting the codes then take the Batt cable off for about an hour. Also check the grounding to the PCM. Do you have a chip?
Old Feb 25, 2006 | 08:19 PM
NATAS's Avatar
check your fuses in the engine bay for the pcm (there are two) i had a problem similar where the truck would stall and i got theft codes and went as far as replacing an iac, key transciever, battery, a set of plugs all to find out i had a loose fuse (40 amp maxi fuse, green)
good luck i hope this helps because i went crazy for almost a month. also...hopefully you get more feedback than i did in here...don't forget to try as many different ways to search your problem you will find more help that way...everybody seems to be caught up in lame a$$ issues like "how much air pressure in my slicks" or "i found a lightning paper weight o e-bay"
Old Feb 25, 2006 | 09:01 PM
SLVRLTNG's Avatar
do you hve a chip? if so make sure it's securely taped in, if it's loose you could have this problem
