Jesel Valve Train??? anyone know about this?
Old Feb 22, 2006 | 02:10 PM
SVTJAY's Avatar
http://www.jeselonline.com/index.php?categoryid=29&
Overhead Cam Follower - Racers have found that the standard O.E.M. cam followers just cannot stand up to extreme RPM's and loads from increased spring pressure, supercharging and fast lift cams. JESEL's new Double Roller Cam Followers operate with less friction by featuring a needle bearing roller on both the valve tip and camshaft to eliminate scrubbing and galling. The billet aluminum body is CNC machined from a proprietary 70 series aluminum that undergoes vibratory surface finish to eliminate any stress risers in the surface finish.
Lash Adjuster Post - JESEL has designed this solid, adjustable lash post to work in conjunction with our overhead cam follower. Each heat-treated, precision ground post is supplied with an assortment of shims to adjust for proper valve lash. The tip of this post is designed to stay engaged into the body of the cam follower. This lash post is available with extended tips for small base circle cams.
Old Feb 22, 2006 | 04:17 PM
Casey02L's Avatar
Old Feb 22, 2006 | 04:20 PM
Herb101's Avatar
Big Bucks Casey - over $2k for roller followers and solid lifters.
Followers are about $100 each and lifters are about $33 each.
Herb
Old Feb 22, 2006 | 04:31 PM
Casey02L's Avatar
Yeah; I saw that.... Mine would have been fine if the snout of the crank hadn't broke.....
Herb
