Trans over heating fix
Old Mar 25, 2000 | 01:09 AM
Metallic Blue's Avatar
Banned
Post
Top!
Old Mar 25, 2000 | 11:58 PM
JIGAWATT's Avatar
Post
I've got a question, does this pan come with a new style pick-up tube/filter? The reason I ask is, if you buy a deep sump pan for a motor doesn't it require a special pick-up. I guess what I'm getting at is, the deeper the oil is the bigger the waves are in the pan.If you have a standard filter in a deep pan you will run the risk of cavitating the pump. Why do you think ford has a different filter for the 4X4 pan.
Jeff, After a convertor drain, before start up you need to know how much the pan holds plus the whole system's capacity. If the pan holds 4 quarts, you better have 5 in the pan and open bottles ready to pour fast at start up. As soon as the motor fires up start filling fast, I have someone start it up while I fill. If you don't do it this way, you can balloon the convertor. If you know the system hold's 14 try to get 10 in fast, after that you can start checking the dip stick.
Kevin
JIGAWATT SVT#2698
N.L.O.C. Member
KSP 4" Filter Kit
4:10's
Bassani kit
TransGo shift kit
AIM 2 inch drop shackle
Old Mar 26, 2000 | 01:27 AM
Factory_Tech's Avatar
Post
Yes, very important to start filling that puppy up AS SOON AS IT STARTS RUNNIG, a suggetstion, get a good funnel and some gallon jugs, (like milk or fruit juice comes in) and pour the fluid into these. If you start with 4 quarts in the pan and have two gallon jugs ready, you'll hit it about right, and add to the dipstick the last 2 quarts, (or however many) The stock 4x4 pan and filter from your dealer ($35.00) will make your capacity what an F-150 4x4 (California) owners manual says, I don't know what that is, we ship them with converters full and 165 Fl oz in the pan. This is just enough to deter rust, final fill is done at the aseembly plant.
Hope this helps
GBE
'00 Silver Lightning
should be here April 3rd
Manufacturing Tech at Sharonville Transmission Plant
Old Mar 26, 2000 | 01:30 AM
Post
Darn, I forgot to mention, I know that minimum temp is a concern, and I dont' know what that temp is,(i'll look into this), but for what it's worth, when the temp in the fluid in the test stands in the plant gets below 125 F, they shut down. So, based on that, I'd be uncomfortable running any lower than that.
GBE
Old Mar 27, 2000 | 06:29 AM
JeffsLightning's Avatar
Post
So is it best to just use the stock filter like isa 4325 did or should we get the 4x4 setup? When at Ford what would I tell them as far as what year and model so I would get the right filter. Would a 99 A4 powerstroke 4x4 work? Thanks for any info... Jeff
99.5 red Lightning
13.2@103
jcks@home.com
Old Mar 27, 2000 | 08:53 AM
1BADTK's Avatar
Thumbs down
lost boost while at track Sunday once after making burnout. pulled to line left with 0 boost all the way down the track. Next time, I made burnout, shifted into neutral rev motor a couple of times boost was good, pulled to line, made good run with boost at max for full run. The pan is not a perfect fix, but close.
Formally isa4325
HALO Member
051199-1132
Red Is Quick: 12.97 @ 107.5
"Only Little Boys Wear Bow Ties"
Old Mar 28, 2000 | 08:54 PM
H8 2 W8's Avatar
Thumbs up
So far so good. Last week I pulled 7500 lbs of concrete and the temp got up just past 150 degrees. Normal driving is right around 125 degrees. At the track it never went above that. Good Luck.
ROB
Old Apr 5, 2000 | 01:44 AM
PFA's Avatar
PFA
Question
Has anyone heard anything new on the trans. cooler that Sal was working on? I think that either the cooler or the pan change may solve my loss of boost problem. I just want to make sure I haven't missed something along the way.
Old Apr 5, 2000 | 03:48 AM
Twisted99's Avatar
Thumbs up
I`m thinkin` both will be the way to go.
Now if I could get this Interceptor to quit settin' codes. I would be almost satisfied..Almost.
By the way Sal's chip and filter combo have made Me a happier individual. I DO recommend his products. Now if He would just let me in as a Sothern distributor and Champeen I could afford one of these trucks strickly fer racin'.
Sal's Filter and Chip
Interceptor Modulator
AutoMeter Pod w/Phantom Boost Gauge
Aim Drop Shackels
Color Matched Mirrors and Taillight trim by AVS. Waitin' on Bedrug and Clear corners. Focus Lens covers.
Boss Amp-Infinity Components-JBL powered Sub
Bel ticket Avoidance Device
JBA's-Carbon fiber kit-Wet Okoles <sp> up next.
Red 99 Lightning #???4/30/99 (Totaled)
Black 99 Lightning #$$$$ 5/25/99
White 88 SVO Merkur Xr4ti
Sand Gold 88 Xr4ti
Silver 95 SHO
Black 2000 Integra Type R #758 adopted
[This message has been edited by Twisted99 (edited 04-05-2000).]
Old Apr 5, 2000 | 05:25 AM
Post
The minimum critical temperasture for a 4R100 is 90 degrees F, below this the converter won't lock up.
Old Apr 5, 2000 | 11:14 AM
Post
I installed the B&M pan last week and everything went good. As per the B&M instructions you are to still used the stock filter. I also reused the stock gaskets instead of the cork one that came with the pan.....they mention that too in the instructions. I put almost 10 quarts back in just for the pan change out. I think eventually I'll dump all the fluid(pan&convertor) and put in some Royal Purple Max ATF. Jeff
99.5 red Lightning
13.2@103
jcks@home.com
