Got some #'s KB/JLP Plenum vs Whipple!!
Old Feb 18, 2006 | 10:43 AM
  #91
tallimeca's Avatar
hahaha
Funny thing is, so many people are so high and mighty on this Whipple thing, if they do have a problem I don't think they will be telling anyone about it.
Come one now. You've been here long enough to know that if someone has a problem with something, they'll be on here in a heartbeat throwing the company and whoever they bought it from right under the bus!!!!!
Old Feb 18, 2006 | 10:53 AM
  #92
rafa26's Avatar
Originally Posted by NCsvt2003L
Vid of Whipple while truck is idling:
http://media.putfile.com/Whipple
Do you have a clip at WOT or at high RPMs ?
Old Feb 18, 2006 | 11:05 AM
  #93
NCsvt2003L's Avatar
No, sorry, I ran out of memory in my camera. When I get the truck back, I will do a vid for you. Street and strip vid.
Old Feb 18, 2006 | 11:08 AM
  #94
rafa26's Avatar
Thanks, man.
Old Feb 18, 2006 | 11:35 AM
  #95
Tim Skelton's Avatar
Originally Posted by LightningTuner
It's not hard to find that info, just go to Lysholm's website. If you don't feel like reading, then just go to the gallery page, and you will see all Whipple blowers installed on vehicles. There is even a picture of a Works Lightning setup on Lysholm's gallery page.
Sal, I think that you are missing Whipple's announcement that, due to supply shortages, it was making its own compressor.
"The new Whipple-Ford Racing system can produce incredible power levels with stock 5.4L Lightning engines as well as highly modified engines. The revolutionary new W140ax compressor has the ability to run nearly 25lbs of boost (engine modifications required) for unheralded performance."
page on new W140ax
Old Feb 18, 2006 | 11:42 AM
  #96
LightningTuner's Avatar
page on new W140ax
I'm aware of that Tim, which is why I said "it's not likely they went BACKWARDS in quality" with the revamped design. If the old one was good, I would like to think the new one would be even better. But again, as I previously stated, only time will tell.
BTW, it's pretty slick how they kept the head unit designations (AX, etc) and just changed it to cubic inches instead of cubic centimeters (140ax instead of 2300ax).
Old Feb 18, 2006 | 11:44 AM
  #97
Originally Posted by SVT F15O
. . . If I am not mistaken, Whipple makes the rotor packs in house and those in house rotor packs are NOT OE in factory vehicles. Lysholm makes the rotor packs for auto makers. -Mat-
That's not exectly correct. Whipple has (or had) a license/distributorship from Lysholm/Opcon for the aftermarket, not OEM. Eaton has the OEM Lysholm/Opcon license/distributorship. So the compressors were identical or nearly identical on the Whipple kits and OEM twin screw apps.
But it appears to me that Whipple has now given up on Lysholm/Opcon completely. Whipple filed suit against Lysholm/Opcon last year, claiming that Lysholm/Opcon was feeding the OEMs and starving Whipple. It appears that Whipple is now making its own compressor (or buying them from some other source).
Old Feb 18, 2006 | 11:49 AM
  #98
I'm aware of that Tim, which is why I said "it's not likely they went BACKWARDS in quality" with the revamped design. If the old one was good, I would like to think the new one would be even better. But again, as I previously stated, only time will tell. . . .
That seems like a pretty big assumption, Sal. Designing and manufacturing a twin screw is incredibly complex. They have been around for decades, but you never saw them in mass production until the advent of CNC. I'm sure that Whipple has the best of intentions, but it's not an easy task.
To pull this off (and steer clear of patent infringement in the process) is a monumental achievement for Whipple. Unless, of course, they are just buying an already-proven design from some other manufacturer or some licensee of Opcon.
Old Feb 18, 2006 | 11:59 AM
  #99
SVT F15O's Avatar
Exactly!
Old Feb 18, 2006 | 01:25 PM
  #100
And for the THIRD time in this thread, I've said that we are going to have just wait and see how the new units play out. All we can do is sit back and wait to hear feeback, good or bad.
Old Feb 18, 2006 | 04:26 PM
  #101
Rob_02Lightning's Avatar
KB
15 pounds of boost, 93 pump gas, 14 degrees of timing.
Pulley combo is a 10 pound lower and 3.5 upper.
KB made 611HP/629rwtq
Whipple
Pulley combo is a 4 pound lower and 3 upper.
Whipple made 604HP/629rwtq
If someone can make this picture bigger so we can see it better, it would be appreciated. Thanks Ronnie
You got it Ronnie
Sorry it was blurry to start with, the bigger I make it the worse it gets : o (
First let me say EXCELLENT POST, Thanks for the great comparision
And of course CONGRATS on the results
I guess like everyone sure I'd like to see the comparison done with the identical upper and lower so we can compare apple's to apple's, but I like what you did by comparing equal Boost levels too. In a way you proved the KB needs to be spun harder to equal the Whipple, which is interesting in itself, and in another way you proved the Whipple can kick *** at less Boost,
which I think we all expected, BUT the most important thing I got from this is something no one has mentioned yet. That is my little ole Magnum put down 606 with a 8lb Lower and 14 degrees of timing. That run was using a 2.7 Upper and Race Fuel, but I hit 590+ many times using 93 octane and the larger 2.9 Upper on my normal summer street program, so in a way even the Mag isnt too far behind.
Old Feb 18, 2006 | 06:05 PM
  #102
Odin's Wrath's Avatar
What compression ratio is your built engine Rob?
Old Feb 18, 2006 | 06:10 PM
  #103
Ok you got me, I might have forgot to mention that
JDM Spec'd Manley STD Bore Pistons, (increased from 8.4:1 to 9:1 compression ratio)
Old Feb 18, 2006 | 06:14 PM
  #104
Rascal.
Old Feb 18, 2006 | 06:46 PM
  #105
NCsvt2003L's Avatar
FirstThanks Rob! That power is actually my daily driven street tune on straight up, pump 93. I have ran the KB up before to 20 psi and have made 670 to the wheels with a 3 " upper and 10 lower.
