Got some #'s KB/JLP Plenum vs Whipple!!
At 5500 engine rpm the Whipple is spinning 15565 rpm.
At 5500 engine rpm the KB is spinning 15675 rpm.
So the KB was spinning 110 rpm faster. That's pretty close.
Thanks for the info Ronnie.
Looks like it's all in the plenum for the KB. Use the C&L and get more lower rpm torque with less peak HP. Use the JL plenum to make it respond on the same curve as the Whipple.
Edit: I rounded down to 2.83 and 2.85 on the ratios so for all you **** retentive math wizards out there add 21 rpm to the 110.
Originally Posted by JimIII@jdm
Im with sal here man....
Try the same pulley combo to see your difference in boost.
Still good testing and very valid info.
JimIII
JimIII
Thanks NC for the test. Look forward to seeing a little higher boost numbers.
I run right about that boost level at the track. -Mat-
put the 10lb on their and then lets see if it will be close. The whipple is making almost the same power with atleast 6 less pounds of boost, it doesn't seem fair to say that the whipple and kennybell were so close. Don't get me wrong i'll give my left nut for a kenny bell , but the whipple is in a class of its own.
Looks Like the ratio's are very close..15# is 15# just like 21# will be 21# when you turn it up!..As far as the KB being out of steam @ 15# No way! i have personally seen 30# on that same KB!
What everybody is failing to see is that the whipple isn't making no where the power over the KB those claimed it would! i heard 50 more HP! @ the same boost levels!
If that were true i would have had 1 a long time ago on my truck!
JL
Originally Posted by Hostile03SVT
unless im mis reading this post... that test does nothing for me.. no justice at all... you tested the KB with a 10# lower, and the Whipple with a 4# lower.. the Whipple made 7 less HP but still the same amount of torque... now do a real test... use the same lower combo and then tell us what really happens... the Whipple will put that KB in its place... it only proves that the Whipple has so much more to give...
What are you talking about... This was a test of equal psi vs equal psi.. It doesn't matter what pulleys get you there...
All this proves is that the Whipple will make high boost with less blower RPM... Some people just don't get it...
The whipple will out perform in the 20+ psi because of it's better efficiency, but most of us won't spin it over 20 psi, so it doesn't matter what pulley combos get you there...
This shows that in the range that 90% of us will be with when we order a twin screw they are equal...
It looks like some people are already figuring this out but....if you learn how to "feed" the KB properly....it will run heads up with a whipple in the upper boost ranges. My KB made 23 lbs of boost with an 8 lb lower and a 2.7 upper and a lot of mods to the intake manifold/spacer side of the blower and also the air cleaner arangement.
Dale
Dale
