tech help
Old Feb 10, 2006 | 10:43 PM
tazor's Avatar
Unhappy tech help
hello, i have a problem, my drivers side bank is running rich, i dont know what to check or where to go for expert help here in so cal, totally stk 2000, any help would be greatly appreciated
Old Feb 10, 2006 | 11:17 PM
l-menace's Avatar
Your O2 sensors may be going bad.
Generally they both go bad around the same time.
If this is a lightning, and the innercooler leaked, that fluid will neutralize the catalytic convertor and foul out the O2's. (been there)
You might want to check the spark plugs, coil packs, and the injectors. (I clean my injectors periodically)
ALso, if you added Exhaust Mods (headers, Hi-flow cats) that makes the truck run richer.
Old Feb 11, 2006 | 11:54 AM
tazor's Avatar
2000 lightning
thanks for your help
Old Feb 11, 2006 | 11:58 AM
Calightnin's Avatar
How do you know your one side is rich? Check your fuel pressure as well.
