Got My Cervinis Hood
Old Mar 29, 2000 | 05:29 PM
BRIMSTONE's Avatar
Post Got My Cervinis Hood
Got my Cervinis Ram Air Hood - without the ram air kit for now. Reason I rushed to get it is because a part of my garage door fell on and dented my stock hood a few days ago.
Some questions for other people who have used Cervinis hoods before:
Should I expect a perfect fit right off the bat, or will adjustments probably have to be made?
There is a small dent on the hood, will this be able to come out with sanding?
Also the body shop I went to get an estimate at today wants $350, that includes priming and prepping, install, paint, and drilling holes so I can use the stock washer squirters. Does that sound reasonable? The price does not include any adjustments that need to be made for fitting/alignment, or fixing the dent - they charge $30/hr for that stuff so I want to get an idea from those who have used hoods from this company, on how long it would take for fitting adjustments & dent removal.
Thanks for any help,
Mike
99.5 Black Lightning
PowerSurge Cone Filter
JBA Jet-Hot coated headers
Flowmaster muffler
So-Cal Lowering Kit; Cal-Tracs traction bars
Watter Wetter
Lo-Jack
Old Mar 29, 2000 | 07:00 PM
Spiro99SVT's Avatar
Thumbs up
Mike,
I had a perfect fit with my Cervini`s Cowl hood, the only adjustments I had was to line up the hood properly on the hinges. I would recommend that you install it and check all corners,you may or may not need some light sanding on the underside edges of the hood. They are thicker just for this reason.As far as the little dent, if it`s a chip in the fiberglass you can repair it yourself very easily.As far as paying 350, that`s just way too high in my opinion.I would look around for a better price, but not have it affect the quality of the job.I have had mine off about 6 times already, ther`s really nothing to installing and removing the hood.My squirters were relocated to the underside of the hood with a kit that was supplied with it.Do you have the ram-air with or without the cowl? I would guess to say that you have no cowl lift, is that why you need to drill new holes for the squirters?
Hope this helps, I would definitly shop around for a better price......
Spiro
[This message has been edited by Spiro99SVT (edited 03-29-2000).]
Old Mar 29, 2000 | 07:30 PM
thepawn's Avatar
Question
Spiro, I don't know what hood you have, but the only one labeled as a 98-00 F150 hood is the RAM AIR hood, there is no cowl to it. The earlier model year hood has it.
Their pic shows no washers, so I'd imagine you have to get it drilled. Mike, let me know how it goes, because I think this is the hood I'm going to buy too.
Here's the pick of it: http://www.cervinis.com/9800F250and9700F150.html
[This message has been edited by thepawn (edited 03-29-2000).]
Old Mar 29, 2000 | 07:48 PM
Spiro99SVT's Avatar
Post
Thepawn,
I have the Cervini`s 3 inch Cowl-indution hood.this is my hood. http://www.cervinis.com/9798F150truck.html
If you do a search you will find the photos of the cowl hood unpainted.
99 SVT Lightning
BLK. #1476 5/20/99
Bassani catpipes
Bassani catback
Downs Air Intake
B.F.Goodrich Drag T/A`s
Cervini`s 3-inch Cowl Hood
A-pillar Phantom Boost Guage
Redline Water Wetter
Sportmaster Flip tonneau
Tow package
CD changer
Best run to date
13.064 @105.33
Best m.p.h. 106.66
"Empty Pockets Racing"Drag Race Team NJ-DE
LAUNCH HARD
Old Mar 30, 2000 | 12:08 AM
BRIMSTONE's Avatar
Post
Spiro,
Thanks, I'm gonna look around for better prices. How can I fix the chip in the fiberglass myself? I'm probably gonna install it myself as well. Also it does come with it's own squirters, they are these little tubes that stick out from the end of the hood, not the most attractive IMO, although I don't know how visible they are with the hood attached. I will see when I check to make sure the hood fits properly. I want to try to do as much of it myself as possible.
Mike
Flowmaster muffler
Watter Wetter
Lo-Jack
Old Mar 30, 2000 | 12:17 AM
Squanto804's Avatar
Post
Brimstone, what did they charge you to ship it and what the cost of the hood? Really love the look !
97 F-150 Black, 4x4 XLT ext.cab,sb,offroad pack.
4" Susp. lift, 3" body
4.56 gears w/LS,
Flowmaster 50 Series w/ duals out rear
36x14.5x16.5 Super Swampers TSL Radials,
16.5x9.75 Weld Scorpio V wheels,
Pre-Runner Bumper w/KC Daylights,
Westin nerf bars,
Pro-Comp Front Skid Plate,
Summit Aluminum Diff cover,
Rancho 9000's and remote,
Lift Lips,
Lighted FORD logo,
K&N Filter,
Superchip,
Bosch Platinum +4,
TransGo Shift kit,
Bug shield,Tinted windows
Sony ES head unit,Sony ES changer,MTX Thunderform sub,Boston Acoustic Pro-Series up front, Polk in rear,PPI & Coustic Amps,Alpine Alarm
Check it out at:
http://members.aol.com/squanto804/scottwebpage.html
Old Mar 30, 2000 | 06:12 AM
Factory_Tech's Avatar
Post
I have the ram air hood on a Ranger, and it looks great. I put it on when the truck was wrecked, so all I paid was the differnce between a stock hood and the new one, install was on the other guy's insurance.
I will say this, compared to ANY other fiberglass out there, Cervini's is THE S**T!
Twice as sturdy as anything else on the market.
Question, can you now get the Ram Air kit that makes it funcional? It's not listed on their web site.
Gregg
Old Mar 30, 2000 | 09:35 AM
Spiro99SVT's Avatar
Post
Mike,
If you check your local auto parts stores they should carry some type of fiberglass repair kits.Follow the directions carefully, you should have no problem.If the hood came with the squirter kit like mine, I would try to make it work I don`t think you would like to add holes to that great hood.What I did to my hood was prefit, and wetsanded all that gelcoat off, this made it alot easier for my friend that painted the hood.The prep work is very important, the more you can do yourself the better price a body shop could give you.
Hope this helps....can`t wait to see the finished product
Spiro
