header bolt question
I have installed a full bassani system about a month ago, and used the bassani supplied bolts. I checked some of the easier to get to bolts last night and they still seem tight. Has anyone else had any problems with the bolts loosening and have to retorque? I am considering ordering a set of stage8 locking bolts if it seems like it is going to be a problem. What do you guys think?
99 red lightning,psp filter kit,Superchip, bassani complete system
2-2000 arctic cat zr440 snopro's
built 5-26-99, #1610
2000 super duty v10
Arctic cat 400 4x4
99 chev c1500 pickup
2000 red Lightning on order 2-14-00
2000 super duty v10
Arctic cat 400 4x4
With header bolts, you torque them to spec and then run the engine and let it reach full operating temperature. Then, after the motor cools down completely, re-torque the bolts. You might want to check them once or twice a year, but in general, this method works well.
The problem isn't the bolts turning, but elongating during the heat/cool cycle. Its a normal thing to happen. The locking bolts just prevent the bolt from turning, so won't actually prevent the "loosening" effect.
I would also not recommend that you use stainless header bolts. Stainless steel expands more than standard steel when heated, so the bolts will have more tendancy to appear to loosen when hot.
