Have any trick to drop the fuel consume?
Hello all
I am going to shipping my lightning to my own country.(Taiwan)
But I get a problem, , I need to pass a fuel consume test when I ship my car back to Taiwan.
The standard for the test is 14Miles/Gallon (5.4KM/Liter)
I think the standard is a little bit hard to pass for my L.(I always run for 12miles/gallon)
So I’d like to ask if anyone know any trick that can drop the fuel consume?
Does SCT 2 tuner will help that?
Thanks a lot
PS:I only change the K&N filter
Thanks a lot
Wow, a lightning in Taiwan? You'll be able to drive across the island in under an hour.
Yeah, I'd try that ^^ removing the belt, if not, see if a tuner can whip you up a lower-performance tune, that may help the gas run too.
--Dan
--Dan
Originally Posted by l-menace
remove your supercharger belt.
Thanks for your advise , I-menace.
But I can't remove my supercharged belt .
The test center they know Lightning is supercharged.
so...
Do not take the belt off the SC. This would cause you to get more aggressive with the throttle and probably cost mileage.
You could borrow some narrower tires and wheels for the test. High pressure is a good idea.
I don't know how the test is run; but, without stop and go traffic, you should be able to get 14 mpg easily. Some guys are getting very good gas mileage with economy programs from their tuner. Sal at PSP has done them. I'd give him, or the tuner of your choice, a call.
Stay off the loud peddle, and you could probably pass the test anyway.
Originally Posted by smolik.tw
Hello all
Thanks a lot
Thanks a lot
From your figures of 14mpg - 5.4km/liter, that means that you are looking at an Imperial gallon and not a U.S. gallon.
Funnily enough, even though, according to tradition, everything is bigger in America, an Imperial gallon is larger than the U.S version
1 x US gallon = 3.8 liters
1 x Imp Gallon = 4.5 liters (or 1.2 US gallons)
Ok, stay with me here. You say that you only get 12 mpg which is 19.31 km per gallon.
Divide that by 3.8 for litres and you are doing 5.1 km/litre anyway which is pretty close.
If you make sure that the truck is in tune and the tyres are pumped up, I'll be t you could squeeze that 0.3 km out of a litre.
Hello all
Thanks a lot
Thanks a lot
Thanks guys ! I am really appreciate for the advises.
For the test , they will use their own octane for it
I think the octane which they are using for the test should be the high octane one.
I can neither change my tires , rims and tires' PSI .
They will make sure I am using stock tire and rims before the test.
also, they have the standard for the tires' PSI .
The fuel consume test has 2 parts. both tests are use machine to control.
First part is to mimic running in the city. 20 M/H without stop for 2 hours.
Second part is to mimic running on the freeway. 60M/H without stop for 2 hours.
Sorry my english is not very good . hope you guys can understand what the meaning is.
I think I will contact to the SCT2 dealer and try to ask if they have any economy programs.
Originally Posted by MAT2CH
With gasoline prices at $2.84 in Taipei they are roughly the same as here in the states. But if they go way up over there you might not be able to afford to drive it. The e-fan and e-water pump should free up a few mpg's, narrower tires at the highest pressure will help as well, but how do they go about testing the mileage in your truck? Did anyone know that gas was the equivalent of $.12 a gallon in Caracas Venezuela.
But I think will be find, because L is a nice car and I really like it !
