Yet another, "What about me?"
Old Jan 27, 2006 | 03:32 AM
HalfTime's Avatar
I can not wait until the track is back in season. But until that time, what do all you pros in here think I'll be running with the following mods...
4lb lower
2.80 upper
90mm MAF
K&N w/cai
Predator (generic tune 'pulley, 90mm maf, 93 oct, cai' for now, custom tune after tax season)
Duel single chamber Flowmasters
High flow cats
F1s
Just to give you guys a base to go off of, I am in NC on the coast, my last run was a 13.6 @ 100.7mph and a 2.01 60ft. 75deg and hummid, drive through wet box, ****ty track prep, the worst I have ever seen! At the time I had only the...
2.80 upper (thought it was the stocker, so I had the wrong tune in)
90mm maf
K&N (drop in fliter, air box cut open on bottom side)
generic Predator (90mm maf, 93 oct) tune
Flowmasters
F1s
I am just looking for some educated guesses on both track times, and hp/tq numbers. Also, I have bean thinking about cutting the front springs one coil, and removing a leaf, that would give me better wait transfer and a better 60ft correct? What are the pros and cons for track reasons?
Thanks in advance for the help guys!
EDIT: What will the boost bypas do for me? I know what it is, I have used the search, I just want to know if it will acctually save me a 10th or so. All I could find on it in regards to the 1/4 mile is "it will take a tick off". Work under WOT only correct? No heat build up on normal driving? Pro and Cons?
EDIT#2: Also, I race it how I drive it, full weight. Spare, Tounue (sp?) cover, Tailgait, tow hitch, and of cource my tool box. (never leave home with out it)
Old Jan 30, 2006 | 04:01 AM
HalfTime's Avatar
bump!!!
