Nitrous or Meth/Water Injection
Old Jan 26, 2006 | 09:38 AM
SmokinSVT's Avatar
I am due for another mod and i am having a hard time deciding which way to go. I want more power but want to remain safe. I currently have a 4#, chip, JLP air kit, and magnaflow exhaust. Any input appreciated.
Old Jan 26, 2006 | 09:44 AM
St Louis Lightning's Avatar
What octane fuel can you get at the pump?
Old Jan 26, 2006 | 10:01 AM
SmokinSVT's Avatar
91 is the highest i have seen around here? I still detonate some times, depending on the weather.
Old Jan 26, 2006 | 10:46 AM
Silver-Bolt's Avatar
Alky/water injection is not a power adder. It is a safety adder. If you have detonation now adding nitrous would be plain stupid. Work on the tune of your current setup before adding anything else. Once you have your current setup optimized then add to it.
Old Jan 26, 2006 | 11:41 AM
As Silver-Bolt was saying, Alky on it's own is not a power adder, but in your case could allow more timing safely and get your detonation under control. That said, I wouldn't want to solve it that way because who wants to keep filling that up all the time for normal driving?
Talk with a tuner that has good experience with 91 oct gas.
-Mark
Old Jan 26, 2006 | 02:04 PM
Dork-N-Beans's Avatar
DUDE 4.10 gears you will trap at about 5k with your setup,and will give you that kick in da **** like the pulley did
