engine swap help
Old Jan 18, 2006 | 12:55 AM
ilovefordtruck's Avatar
engine swap help
hi all, i just install a new engine on my 02 f150, got the flex plate on the torque convertor also. but my bellhousing is missing a couple of bolts. and dowl pin is aligned but since i have missing bolt the bellhousing is not completly close together. can i drive it as is? since the flex plate is securly bolt on to my torque convertor or do i have to take buy new bolts and since the missing bolt is on the top , i have to take out my intake manifold to gain access.
please give me input suggestions.
thanks in advance
triston
Old Jan 18, 2006 | 01:17 AM
Hostile03SVT's Avatar
umm im just curious.. did you check to make sure that your torque convertor fully installed and locked in place?? there shouldnt be a gap there unless the convertor was not installed properly.. i would look into that..
Old Jan 18, 2006 | 01:33 AM
yes it's locked in place. the gap is cause by not completely screwing in the bolt for the bellhousing ( i think ) but i am very sure that the torque convertor is locked and spins freely
Old Jan 18, 2006 | 01:59 AM
sorry i cant help ya anymore then that bud thats all i can think of right now..
Old Jan 18, 2006 | 02:06 AM
mark150's Avatar
2 bolts should close the gap if the converter is installed properly. If not you could the ruin front pump, seals, snap pieces off the bell housing. I would get bolts first.
Old Jan 18, 2006 | 06:54 AM
CSHEETS's Avatar
I wouldn't drive. If you do you have a chance of missing up your pump. Just go get some other bolts to finish up the job, don't do it half ***.
