QA1 leaking
Old Jan 14, 2006 | 05:25 PM
chief40al's Avatar
Question QA1 leaking
I was checking things under the truck and I found oil on the case of one of my rear QA1 shocks.
Is there any way to check where it is coming from and can I fix it or should I send it back?
I put them on in May 05.
Old Jan 14, 2006 | 05:34 PM
dirtchicken's Avatar
Several others have had this problem. You SHOULD be able to take them apart and put new seals in them. I hope you don't have to send them out.
Old Jan 14, 2006 | 05:43 PM
Hostile03SVT's Avatar
Wow, Al i cant believe they are leaking.. but i believe what Dirtchicken said is true.. the whole point of these QA1s other then the use of tuning your suspension, is to rebuild them too.. but for them to need to have that done already is insane.. goodluck to you pal..
