Toe in - Toe out
Old Jan 14, 2006 | 06:49 AM
kerniki's Avatar
Toe in - Toe out
Anyone know the + / - Toe in for an '04' Lightning? getting the alignment done today and no doubt the UK Tyre house will not know
Thanks in advance
nick
Old Jan 14, 2006 | 09:07 AM
RhinoSlug's Avatar
Unless its an old school shop, their computerized setup would have the alignment specs for all known vehicles.
Old Jan 14, 2006 | 09:23 AM
Shorty's Avatar
Tell them to make it go straight.
Old Jan 14, 2006 | 10:06 AM
SLVRLTNG's Avatar
Lightning specs:
L.H. Caster: 6.9, +/- 1.0 Deg.
R.H. Caster: 7.4, +/- 1.0 Deg.
L.H. Camber: -0.5, +/- 0.7 Deg.
R.H. Camber: -0.5, +/- 0.7 Deg.
L.H. Toe: -0.05, +/- 0.15
R.H. Toe: -0.05, +/- 0.15
Lightning Owner preferred:
LH Caster 6.7
RH Caster 7.2
LH Camber -0.5
RH Camber -0.5
LH Toe -0.05 (slight toe in)
RH Toe -0.05 (same)
Base F150: (tolerances same as above)
L.H. Caster: 6.2
R.H. Caster: 6.7
L.H. Camber: -0.3
R.H. Camber: -0.3
L.H. Toe: 0.03
R.H. Toe: 0.03
Ford Alignment spec:
Lightning Owner autocross preferred specs:
LH Camber -0.7
RH Camber -0.7
LH Toe OUT 0.05
RH Toe OUT 0.05
Old Jan 14, 2006 | 08:03 PM
Dan_03Lightning's Avatar
SLVRLTNG
Impressive!
Old Jan 15, 2006 | 12:46 AM
SVT_KY's Avatar
In a nice hard copy for the glove compartment ...
Click Here
Old Jan 15, 2006 | 03:59 AM
kerniki's Avatar
Originally Posted by SLVRLTNG
Lightning specs:
LH Caster 6.7
RH Caster 7.2
LH Camber -0.5
RH Camber -0.5
RH Toe -0.05 (same)
L.H. Caster: 6.2
R.H. Caster: 6.7
L.H. Camber: -0.3
R.H. Camber: -0.3
L.H. Toe: 0.03
R.H. Toe: 0.03
LH Camber -0.7
RH Camber -0.7
LH Toe OUT 0.05
RH Toe OUT 0.05
top notch, was not expecting that much
BIG THANKS Slvr
now I can really confuse the local tyre guys
