Lower A-Arms
Old Feb 27, 2000 | 01:08 AM
JIGAWATT's Avatar
Question Lower A-Arms
Someone had their lower a-arms changed out. they gave the part#. I was just curious if you knew if the old arm's had the SVT emblem's. Also do the new one's have the SVT emblem's.
I was under my L, and saw that I have the SVT emblem on mine.
I also saw that the driver side lower a-arm, back bolt is moving from side to side. I remeber about the upper a-arm's, some didn't have the cam-bolts. Do the lower a-arm's take a cam-bolt also? I would think this should be a soild type mount, non-moveable. Is there anyone that knows how to fix this problem?? Or, what has anyone done for it?? Does Ford have an SSB or TSB on this?
Kevin
JIGAWATT SVT#2698
N.L.O.C. Member
4:10's
Bassani kit
TransGo shift kit
AIM 2 inch drop shackle
Old Feb 27, 2000 | 01:35 PM
alphadoggy's Avatar
Unhappy
See my reply to Cobrarose "Lower control arm fix".
Old Feb 28, 2000 | 01:10 PM
redlite's Avatar
Post
JIGAWATT, it was me who had lower control arms replaced. See my reply to Cobrarose on, "Lower control arms fix, what is fords answer"? Has part numbers listed.
I have no idea if there was any outward indication if they where SVT parts. The service writer did remark to me that the replacement control arms where more heavy duty appearing than the old ones.
