Rich Code
Old Dec 25, 2005 | 07:17 AM
madferraristi's Avatar
Rich Code
Anybody know what A/F number it takes to set a rich code P0172/P0175?
Old Dec 25, 2005 | 09:44 AM
Ruslow's Avatar
The computer does not look at the A/F so much as the short and long term fuel trims if they stay at one end or the other to long that is what sets the code.Stan
Old Dec 25, 2005 | 09:53 AM
chucks bp's Avatar
RUSLOW is correct, the computer is looking at the short term and long term fuel trims as long as they do not exceed -25%to +35% short term and -35% to +35% long term for any length of time there will be no code set, it is when the computer is trying too hard to control the mixture causing high fuel trims consistantly, that a code is set.
Old Dec 25, 2005 | 11:16 AM
Makes sense, thanks for the info.
Old Dec 25, 2005 | 01:34 PM
gbgary's Avatar
Old Dec 26, 2005 | 09:01 AM
raider's Avatar
Mad contact me on IM and I will explain the long and short term fuel tables to you
Old Dec 26, 2005 | 09:53 AM
Rob_02Lightning's Avatar
WOW
Your throwing a System too Rich code for both (Bank 1) + (Bank 2)
I can only add that I was throwing one of those codes
and meanwhile I was melting plugs left and right ?????
Old Dec 26, 2005 | 11:02 AM
Rob,
Then how did you explain it?
Old Dec 26, 2005 | 11:50 AM
liteitup's Avatar
Rob,
he bumped the timing and sprayed the crap out of it!!!
then he wrote a 27 paragraph post
Old Dec 26, 2005 | 12:03 PM
Ok MAYBE I deserved that
We really never did unfortunately
But what I'm getting at (and I believe others are trying to say too) is sometimes the problem is NOT it's too rich, instead the problem is it's too lean and the computer is trying to compensate for it. THEN during it's normal self diagnostics checks it reads it as too rich.
There is more to our adaptive learning and self diagnostics than most realize..
BUT during the new motor build a few things were found that could answer my former probs, one was a bad wire to a Oxygen Sensor, we also changed an oxygen sensor and that harness, along with new fuel rails, a new fuel regulator and plenty of other stuff.
Good luck and please do let us all know when you figure it out.
Old Dec 26, 2005 | 12:50 PM
raider's Avatar
I know that I had a problem datalogging with adaptive turned on....I turned it off when I did all my datalogging
