Fog Lamp Replacement
Old Feb 22, 2000 | 01:37 PM
Thunder's Avatar
Post Fog Lamp Replacement
Does anyone know whether the PIAA 990HID can be used as a direct replacement for the fog lamps?
If so, does anyone know where to get these at the best prices?
Thanks!
Thunder
rainmaker@attglobal.net
Black 97 Expedition EB 5.4L 4WD
Mods: Lightning front fascia, Lightning Wheels, Pirelli Scorpion Zero 285/55VR18, K&N Gen II Kit, JET Chip
Brembo 14" disc brake kit coming right up!!! And hopefully a Lightning engine too!!!
Audio: McIntosh MX406, McIntosh MCD4000, Zapco SX-SL, Zapco EQ30, Genesis Monoblocks (3), Genesis Dual Mono, Dynaudio System 340, Dynaudio System 220, JL Audio Stealthbox
[This message has been edited by Thunder (edited 02-22-2000).]
Old Feb 22, 2000 | 09:09 PM
noelvm's Avatar
Talking
What a wonderful idea. The stock units don't put out that much light and all the lens covers are cracking. What are the lens covers of the PIAAs made out of? Are there clear covers available?
Noel
70 Vette, LS-6, 99 Red Ligntning, K&N, Syn Oil. Looking at chips.
[This message has been edited by noelvm (edited 02-22-2000).]
Old Feb 22, 2000 | 09:26 PM
Thunder's Avatar
Post
www.hidlights.com sells a 9007 HID replacement kit for the F-150. There's no price on the site yet and I'm still getting a quote. You can find it under the applications page. You can email ben@hidlights.com if you need to get in touch with them. I figured HID main lamps and HID driving lamps would be awesome. The only problem is that HID lamps are not hi/lo swithcable...you lose your brights. But then again, you might not need it if you have both main and driving lamp HIDs.
The advantage of doing this is that it draws less current (equivalent of a 35w bulb), thereby reducing the load on the alternator which then allows you to produce more power...hahaha, excuses excuses!
Old Feb 23, 2000 | 02:13 AM
Thunder's Avatar
Post
According to Ben of hidlights.com, the 9007 kit for the main lamps "is $950. Power of the HIDs is 35 watts rated at 3000 lumens which is 3 times the output of a standard 55 watt bulb."
