Running Lean Question
Old Dec 16, 2005 | 09:00 PM
tespy's Avatar
Just finished cleaning the Eaton and the after cooler, changed plugs and put in NGK's, Installed Chicken's new cool aid and put in RPM's Oil Separator. When I installed the oil separator, I ran the line to the PVC ( as per the directions ) and I also ran a hose to the driver side. In running the hose to the driver side, I had to eliminate the line that went to the bottom of the rubber boot below the throttle body. I was told this could make it run too lean. How will I know this and how do I correct this if it is too lean?
Old Dec 17, 2005 | 12:03 PM
HalfTime's Avatar
get a air/fuel meter, or dyno tune. Then get a custom tune to fix it.
Old Dec 17, 2005 | 01:38 PM
fastdailydriver's Avatar
get a air fuel meter,and talk to a tunner ,with out the meter you have know way of knowing ,its always good to watch the meter even with a tune,.air fuel ratio is very important to engine life especially with our motors.
Old Dec 17, 2005 | 02:14 PM
SMOKINTRUCK#1's Avatar
I think Sal powersurgeperformance has a sale on a Wideband commander much better if, your modding!
Old Dec 17, 2005 | 10:43 PM
tespy's Avatar
I sent Sal some mail at PSP. Thanks
Old Dec 20, 2005 | 10:10 AM
madferraristi's Avatar
Check here for a Wide Band too. http://www.nhtoc.net/vbforum/showthr...ight=Christmas
Old Dec 20, 2005 | 11:09 PM
Twisted99's Avatar
When it sets a lean bank code you will suspect ....
