Question for those with aftermarket boost gauge
Is it just me or does it seem that the phantom gauge moves very differently than the factory. The factory gauge often shows a constant boost (+6-8) while the phantom is rising/declining. The trucks performance isn't different. It seems most noticable at higher speeds and WOT.
At vacuum, the gauge is right on with throttle. Last night when testing the chip, while cruising at 60mph, both the factory and phantom showed vacuum. BUT, when pedal hits the floor, both gauges rise(Factory maxs out) and then the phantom slowly starts to decline. Meanwhile, the factory stays maxed out, and about 1-2 secs after the phantom is back to little/no boost the factory returns to little/no also.
Is the factory gauge that inaccurate?? or is it possible the phantom gauge is a bit off??? Is this just typical????
Never had a boosted car before, and before installing the phantom gauge I never much payed attention.
Thanks again
Brian K
99.5 Black
[This message has been edited by Brian K (edited 02-15-2000).]
Thanks again
Brian K
99.5 Black
- Tinted Windows
- PSP Intake
- Clear Corners
- Autometer "Phantom" Boost Gauge
- SuperChip "FlipChip"
- Bedrug Coming Soon
- Bolt ons & Faded Paint
- School Bus Yellow
- Its just cool
not sure what you mean by "bouncing around", @ vacuum mine responds more because is reading a lower pressure than the stock guage can, but it sure doesnt bounce around, seems to be very accurate.
99' SVT Black Bolt NLOC #392
Clear Corner Lenses
Autometer Boost & Air/Fuel ratio Guages
best run 13.54 @ 101.35
**Unlike Lightning I will strike you twice**
[This message has been edited by Yoda (edited 02-15-2000).]
Clear Corner Lenses
I'm with Yoda, no bouncing around. The gauge moves with the throttle.
Jerrod Gross
99.5 White Lightning
#1414, May 19,1999
Snuglid, sprayed on bed liner, 8.84sec/79.8mph (1/8th)(before mods.)
SHM mass air/conical filter, ASP blower pulley
phantom boost gauge
Jerrod Gross
#1414, May 19,1999
phantom boost gauge
DITTO
PFA
'99 WHITE LIGHTNIN'
#0873--1 of 866--
RHINO, Soft cover, LoJack, Valentine 1, Mobil 1
Superchip, Water Wetter, Phantom Boost Gauge
Best ET to date-13.54 @101.51MPH--10/29/99
Best MPH to date-102.33MPH @13.68
Best 1/8---8.70 @80.82MPH
NEWEST ADD.--16" SNOW TIRES
SuperChip out for now
'98 Red Lincoln Continental
1/8 mile--10.25 @69.64MPH
1/4 mile--15.82 @88.16MPH
PFA
'99 WHITE LIGHTNIN'
#0873--1 of 866--
